Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Top burnner will not turn off
When i turn on the top burrner on the stove it will not turn off unless i unplug it
  • Kenmore Master
  • 8,220 Answers
That is going to be the switch. Robert shaw has a generic one 5500-200 for around $30 bucks. It has 5 legs L1,L2, H1,H2 and P
Fairly simple to replace. Comes with directions. Has multiple mounting posibilitys and works with 6 or 8 inch burners.
Posted on Mar 03, 2009
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
After cleaning the electric starters keep trying to light without being turned on. When i actually attempt to light the burners they are not lighting.
unplug the range untill the switches dry. Water will make the switch to actavate the spark ig. water will also cloge the holes in the burrner heads.
Oct 31, 2009 | Cooktops
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Oven will not work unless range is lit
You probably have a neutral return that is open. By turning on the stove top you are completing the path of return for the bake element. Work back from the element (unplug the oven first!!!) and check continuity back to the plug. Again, make sure you unplug the darn thing from the AC outlet!
Mar 12, 2009 | Maytag MER5775Q Electric Kitchen Range
My ignitors on the stove top won't turn off, how do I turn them off?
One or more of the ignitor switches is stuck.
It must be replaced.
Once you remove the front panel, you can unplg one a a time until the clicking stops. The last one unplugged will be the bad switch...unless you have more than one bad switch.
Mar 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ignition problem on stovetop
was the unit cleaned recently?? if so i would check all the burrners for clogs
Jun 04, 2008 | Hotpoint RGB528 Gas Kitchen Range
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
On Light Won't go off on cooktop
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Jan 29, 2008 | Cooktops
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
77 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
