Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
I have a poulan pro 220 16"
And I need to know how to hook up the fuel lines back onto the 2 carburetor inlets
  • Anonymous Mar 18, 2009
    what line connects to what apart of the bulb
  • John McKinney May 11, 2010
    If you can get me the model & serial numbers, I can get you a manual to help you with that.
  • 12 Answers
Carb has 2 inlets top inlet connects to tank line with filter on it. Bottom inlet connects to bulb other line from bulb returns to tank on bar side.
Posted on Mar 15, 2009
  • Kurt Huebsch Mar 28, 2009
    draw side of bulb goes to carb. push side returns to tank.
Connected carburetor to prima bulb& tank
Here is the way to hook up the fuel lines
connected-carburetor-prima-bulb-amp-0snlkc2idhfslary3a2ev3kp-4-0.jpg Note: I put it together outside of the saw so you could see how it is hooked up. Fuel filter/pickup >>to>> Inlet on carb >>to>> Outlet of carb >>to>> to inlet on Primer bulb(shorter post) >>to>> Outlet of primer(longer post) >>to>>Fuel tank (usually has a retainer in tank to prevent fuel line from coming out.)
Jan 25, 2016 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Put a new carburator on and don't know how to hook
Hi janemueller...
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Free answer...Please take time to rate me
Jun 15, 2011 | Poulan Garden
Poulan chainsaw 2450 picture of gasline hoses conected
OK here goes, no pic but I will describe the best I can. This model should be equipped with a primer. The first thing you need to do is identify which connector is suction (in) and which one is return (out). Once you have done this it's simple. The return (out) has a line that goes right back to the tank. The suction (in) line hooks to the carburetor. The main fuel line from the tank with a filter on one end has the other end that connects to the carburetor. Now, with two fittings on the carburetor, find the one closest to the fuel pump cover (usually held on by one screw). This is the inlet fitting to the carburetor. This is where the fuel line connects that goes inside the tank with the filter on it. The lower or opposite fitting is where the suction line from the primer connects. This should do it. The return (out) line is usually a larger OD line than the suction & fuel line, which are the same size OD lines.
Feb 12, 2011 | Poulan Garden
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
There are 3 fuel lines on my Poulan 2150, 2 - 1/8"...
The 'vent looking device' should be the fuel filter--remove it and make sure it is not plugged. The other end of that line should go to the carburetor inlet port near the top. When you get the line connected, pump the primer several times (tank is filled with fuel mix and the small line returning to the tank is pulled loose from the primer port) to see if it pumps fuel through the carburetor into the primer bulb. If it does not, swap the line from the carburetor to the other primer port and retry pumping again. If fuel fills the bulb, then plug the line from the tank to the vacated port on the primer. This will pump excess fuel back into the tank. Hope this helps!
May 17, 2010 | Garden
I have a Polan Model 2375 Wild Thing Chain Saw. The fuel lines have deterioated and I need to know correct routing of fuel lines. The primer bulb has to line connectors, one small diameter and one large...
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
SmallEng.com
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My 2 cycle poulan pro weed eater won't start. it's about a year old and worked fine 2 weeks ago
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see day light through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 03, 2009 | Poulan Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
1,063 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
