Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Power on but no picture?
Hi i have 36 sony wega when i turn it on no picture or notting after 20seconds the bottom light ill turn on (lamp)can you help pls.
  • 294 Answers
IS IT A PROJECTION T.V. ? IF SO IT SOUNDS LIKE YOUR LAMP IS BLOWN AND NEEDS REPLACED
Posted on Mar 07, 2009
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have Sony Wega and the picture just cut out and went to black. The sound wont come on and the TV wont even turn on. The light at the bottom of the TV flashes lamp light. We took the lamp light out and...
if u take out the lamp the green light will flash ,its not detecting a lamp at all.a bad lamp is being detected before you took it out.u will have to replace the lamp before u get a picture again
Sep 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony Grand Wega KDF-E60A20 purchased in 2007 keep going off for 15-20seconds then return to nl screen for a few minutes then repeat dark again. Any suggestion?
Its time for new lamp as current lamp is reaching to an end of its working life and causing these symptoms.
Lamp replacement procedure is written in user manual and its easy.
Please buy Sony original lamp for good picture in tv.
Hope this info will help you, let me know if you have additional question.
Thanks.
Apr 25, 2010 | Televison & Video
Sony Grand WEGA KDF-55WF655 picture and sound are going on and off. The green light flashes when they are off and when they come back on the picture comes on first then the sound.
These are symptoms of weak lamp as lamp in tv is reaching to end of its working life and will be replaced to fix this issue.
Lamp replacement procedure would be written in user manual and its easy.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega problems help please!
the first place to start is change the lamp
Mar 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
