Question about Kenmore Elite 45986 Front Load Washer
F 11 while washing clothe the washer stops and error code F 11
    Scholar:
  • 106 Answers
Catriver has a solution for this:
F11 is a serial communication error. Communication between the central control unit and the motor control unit cannot be sent correctly. Possible solutions: Check the harness between the two boards for loose connection. Driver motor, main board or motor control board may be bad. I have come across a number of these with loose connections and bad main boards. Put it into a test by pressing drain/spin on the left side. Then press the spin speed button on the right until no spin is lit. Then press the pre-wash button on the right 4 times until 00 comes up in the display. You are now in the automatic test mode. Let it do it's thing about 15 minutes and see if the error comes again.
Posted on Mar 01, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Kenmore elite f 51 code
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
  • Sponsored Links
Prevention/Solution
  • Check around the inner washer and underneath for any lost clothes or jammed objects. This can be anything from toys to shoes.
Considerations
  • If there are no objects, your washer parts may need to be cleaned or replaced. Call Kenmore at 800-4-MY-Home to talk to a service representative and find out about replacement parts.
Types
  • Along with "F51", error codes "F1" and "F50" could mean the same thing. Check for these error codes and follow the same procedure with your washer.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz346p9Y6ro
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code 3E Maytag washer
it overheated... turn it off, wait 10 minutes and take out some clothes
Aug 31, 2009 | Maytag MAH6500 Neptune Front Loading...
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
Kenmore Elite 45986 Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Robert Rankin
