To owner of question, you will have to clean out the DS Lite Cartridge Slot since there must be too much corrosion on the pins or dust inside the Cartridge Slot. Try using rubbing alcohol and a q-tip to clean the inside of it. Then use a dry q-tip to dry the rubbing alcohol. To Guest - If you open up the DS Lite, you will see that the cartridge slot is covered with metal. You can't get into it without breaking it apart. Your best bet is to buy a replacement Cartridge Slot off of Ebay, desolder the old one, and then solder the new one on.
hi i have same problem with my daughters but i can see there is a pin in the ds slot that looks like it has lifted trying to get into the ds with screw driver but having no luck .
Ds Works great. When I put DS cart in it won't boot and the screen is black. GBA carts work fine
