Back yard mechanic has reached impasse repairing truck. replaced carburator, cleared out blocked catolitic converter, replaced fuel filter, time chain and guides, and now there is water in the gas, AND the muffler blew up!
SOURCE: need to replace timing chain 1994 toyota truck has
Be sure to replace all the gears, tensioners, guides and seals if your going to replace the chain. Perhaps the water pump as well if it hasnt been replaced in a while. Sounds like alot of work with that many miles unless the engine has good compression on all cylinders and the head is in good shape as well. You might consider finding another engine if you plan on keeping this truck for a while. By the time you do all the work and pay for all the parts to do the timing chain, you could find a low mileage engine for a few bucks more as long as its tested for compression and has documented miles on it.
SOURCE: I just replaced the fuel pump on my 1987 toyota
You bet.
Also check the timing belt. If the distributor is not turing the fuel pump also will not run.
Hope this tip helps.
R/
David
