Question about LG Art Cool LA121HNP Split System Air Conditioner
Displaying "Co" code, and running when turned off with the remote
We also have the LG Art cool. It is displaying the code" Co", which i haven't seen before. We too have had the "C6" code before. Although the unit is turned off at the remote, it is still running with the "Co" code on the unit display
  • janinehunsto Mar 05, 2009
    Thanks!  It has been fine since i posted....just turned it off at the fuse box; but if it happens again, i will get it checked :)
  • 400 Answers
It sounds like you have lost communication between the indoor and outdoor units. This can be one of two things. Either the connection indoor or outdoor is loose or bad, or a rat may have eaten the cable in cieling.
Posted on Mar 05, 2009
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
C9 error code lg cool art
let the technicians do it for you,one of their sensor got faulty
Apr 21, 2014 | Heating & Cooling
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
May 04, 2010 | LG Art Cool LA181CNW Split System Air...
My LG LAN125 mini split heat pump occasionally shuts down in cooling mode while displaying the code CA. The LG tech tells me there is no such code. When this happens, I have to cycle power off and back on...
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Jun 28, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Error Code on LG Art Cool
error code CH22 is either compressor or inverter fault.
Jun 01, 2009 | LG Art Cool LA091HNP Split System Air...
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Error C5 LG Art Cool Split System Air Conditioner
Probably a capacitor in the either the compressor or outdoor fan. Don't know if they are dual capacitor or each has it's own. This is just according to the other posts on this site. I would call in a tech to have a look at it. Should be able to diagnose this in about 10 minutes.
Jan 05, 2008 | Computers & Internet
Lg ductless no ac
I may not be of much help but I may be able to guide you into some diagnosos. If there is a communication problem between the inside and outside unit, both on the inside and outside units a colored LED will bling 5 times then pause for 3 seconds. The 33 and 44 codes are confusing to me because I have never seen this. Try resetting the outside unit with no call for heat or cool from the inside unit. After about 20 seconds, restore power to the outside unit. Go in and turn on the remote and make sure you lower the cool setting more than degrees cooler than the room temp. After 3 minutes the outside unit should turn on. If you get an error code of either 1, 2 or 5 blinks document it for the technician. If you continue to get your 33 and 44, you have a bad control board. If all else fails, press and hold the button located on the lower left side of the art unit and hold for about 5 seconds. If it still no longer works, now you will need the help of someone who knows these units.
Sep 08, 2007 | LG Art Cool LA121CNP wall/window Air...
LG Art Cool LA121HNP Split System Air Conditioner Logo
722 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
