Question about Philips 50PFP5332D 50 in. Plasma Television
Phillips 42 In Plasma Blinking Red Light Only
Set Is 14 Months Old We Have Two Of These With The Same Problem
Phillips Has Been Useless
  • Steven Rivera
    Steven Rivera Mar 01, 2009
    Found The Answer 2 10 Volt 33000mfd. Caps At Bottom Of Power Supply Board,Changed Them To 16 Volt Versions, The Old Ones Will Look Swollen.
  • 90 Answers
Blinking link means there is a problem with the software -- usually this is caused when a fuse goes bad or the power supply board needs to be replaced due to a problem --- most repair places replace the whole board - nobody fixed one broken part
Posted on Mar 03, 2009
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
TV set won't come on.
It looks like your <a href="http://www.digitaldirect.co.uk">TV</a> is faulty. You will need to get a qualified engineer to repair it.
Jan 03, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
42" panasonic viesta plasma tv cuts off after about 30 minutes
Hello gws51,
This sounds like a shutdown circuit proble, which is caused by the draw of excessive current. I would suggest that you have a qualified TV repair person look at you set and repair it.
I hope this helps
Thank you,
Shuttle83
Jul 16, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Phillips Plasma 42" TV
what model do you have?
Jun 23, 2008 | Televison & Video
Phillips Plasma 42PF3320
I have phillips 42" plasma tv it has 7 red light flashes at start up and locks out
Jun 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
TH-42PD50U power light 8x blink
alletram sounds like a high voltage arc got your tv, it might just be a capacitor blown very inexpensive to fix. find some one that does component replacement.
Dec 08, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV Won't Turn On
My phillips 42" is the same way. Just started popping up the settings menu the other day and wouldn't stop popping up until I downloaded the software upgrade from the Phillips web site. But now, two days later it won't do anything but give that same annoying red blinking light. The customer service says to take it to an authorized repair center. sounds like they have a ton of these calls everyday. The solution is to buy it from Costco, and make sure you return it and get a new one before their return policy expires.
Apr 22, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Philips 50PFP5332D 50 in. Plasma Television Logo
182 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
