Samsung LE40R74BDX 40 in. LCD Television
Problem for Samsung LE40R74BDX 40 in. LCD Television
Whilst watching tv after 10 to 15 min screen goes
By dave_bennett on Feb 28, 2009
whilst watching tv after 10 to 15 min screen goes blank but sound ok ,when u turn tv off then back on u get pitcure for about 10 minthen goes off again
Same Problem
Mar 28, 2009
-   I have the exact same problem!! Did you ever find out how to get it fixed??-   asern
Solution #1
posted on Sep 18, 2009
Not Rated)
arthurtaylor
Rank: Master
Rating: 83%, 3 votes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Was this helpful?
Yes
No
Popular Solutions for Samsung LE40R74BDX 40 in. LCD
Questions and Unsolved Problems for Samsung LE40R74BDX 40 in. LCD
Do you recommend Samsung LE40R74BDX 40 in. LCD Television?
Answer
Answer
hi i am trying to put on the stand on the samsung le40b650 can you help as the platic clips look... (More)
Answer
cant separate the lucite neck of the base from the monitor on the p2370 monitor to send it back in... (More)
Answer
I have just bought a 40" samsung LCD tv and the TV channel doesnt work. I think maybe I have to... (More)
Answer
i have a 40 inch lcd saumsung series 5 tv cannot pick up freeview stations my dish is correct for i... (More)
Answer
how do I remove the stem of the stand on the samsung 933HD tv??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
