FixYa.com
Tags:
Intel InBusiness Internet Station  Router
SS101TX8EU & SH100TX8EU
By Beresford - usenet poster
I have the following configuration :
SS101TX8EU with : 2 PC's with a PILA8461
1 SR10TPSEU
1 SE10TEU
on another location
SH100TX8EU with : 5 PC's with a PILA8461.
I can't connect the SS101TX8EU & SH100TX8EU, i tried every port on both
devices, using a normal and/or crossover cable. All the cables are
CAT5.
When i connect one cable from the SS101TX8EU straight to a PC, there is
no problem.
What can i do to solve this problem?
info.vcf
1K
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
kioner
kioner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi again,
Assuming these workstations are connecting successfully at 100Mbps to the hub or
switch, then if you take the same cable used for that 100Mbps connection, and connect
one side to the "out to hub" port on the hub, and connect it to any port on the
switch EXCEPT the "out to hub" port, does it work? I am trying to eliminate a cable
issue, either pairing, or pinout.
If this still does not work, please contact us by telephone. From North America call
916 377-7000 - Otherwise see #
Thanks,
Will B
Internet Support Engineer
Intel Corporation
Networking Products
* All other brands and names are property of their respective owners.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Hello Will,
The hub & the switch both works fine with a PC, the problem is to connect the hub
to the switch. I think there must be a problem in the hub or the switch. How
can i test it?
Greetings,
info.vcf
1K
Solution #3
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Hi Ronny,
Assuming you can also connect the SH100TX8 to a PC with the same cable, then
all that should be required would be to use the "out to hub" port on the hub,
and connect it to one of the standard switch ports, using a straight through
CAT 5 cable. Or, connect any of the standard ports on either hub together
with a CAT 5 crossover cable. Make sure they are all wired correctly
according to # and
otherwise, I am not sure what could be the problem. Is the above what you
have already tried? And does the hub work correctly with the PC's?
Thanks,
Will B
Intel Corporation
Networking Products
Can you Help with these Routers problems?
Routers
Wireless and Wired Router
I currently have a desktop and... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
