Question about Delta JT160 Shopmaster 10 Amp 6 Inch Benchtop Jointer
Infeed Table leveling
The front (leading) edge of my in-feed table is approx 1/32" lower than the back (next to cutter) edge.  Is there a way to adjust this to absolutely parallel with out-feed table?
  • 2 more comments
  • 1bigguy Mar 01, 2009
    The infeed table is flat -- it's fine -- it's just lower on the leading edge which causes the workpiece to rock front to back as it passes across the cutter.
  • 1bigguy Mar 02, 2009
    I understand that the in-feed table is suppose to be lower than the out-feed table.  That is not the problem.  As I said -- the leading edge of the in-feed table is lower than the trailing edge of the in-feed table -- the in-feed table slopes upward toward the cutters.  That is what I don't know how to fix.
  • Anonymous Mar 31, 2009
    i have the same problem as you and don't know what to do i think i might be applying to much presser.
  • Dean
    Dean May 11, 2010
    So you want the infeed table to be parallel to the outfeed table, or your infeed table alone is not flat front to back?
  • 285 Answers
Well, the infeed table is supposed to be lower than the outfeed table. This is how the jointer actually removes material to flatten a face or board edge. What is important is that the the outfeed table is level with the top of the cutterhead blades, so as you push material through the cutterhead, the outfeed table fully supports the workpiece.
The infeed table is supposed to be adjustable up and down to remove different amounts of material.
If both infeed and outfeed tables were aligned, no material would be cut (assuming the outfeed was aligned with top of the blades).
Posted on Mar 01, 2009
How do you set up planer blades
Planer blades are set in the cutter head, they must be set at the same height and level. The feed table is lowered to set the depth of cut and the output tabled is adjusted to support the work peice after it passes over the blades
Aug 29, 2014 | Crafts & Hobbies
Adjustment on dewalt planer
I don't know which planer you have, but if all the planing happens on the top side of your stock then all surfaces underneath should be at the same level.
If you have a fancy planer that cuts on the bottom side, then the outfeed table should align with the cutters and the infeed table would be adjusted below that by the cut thickness (like a jointer
Mar 17, 2014 | Dewalt DW7351 Folding Table for DW735
My outfeed table does not run level with infeed table . How do i adjust?
The most important part of the jointer is that the cutting edge is perfectly level with the out feed table, then, bring up the infeed table, with straight edge on rear, make all adj necessary to get these things lined up flat, not level, but flat, straight, even. Then it will cut perfectly flat and even. no snipes,. Hope this helps.
Feb 05, 2012 | Delta Masonry Tools
HOw do I adjust the tables so I do not get a snipe?
Adjusting a jointer to relieve snipe can be trickey but here are a few procedures that will help.
-The two tables on the jointer are adjustable, the front (infeed) is what you adjust for cut depth.
- The back (outfeed) needs to be the exact hieght as your knives
The outfeed needs to be adjusted first
-unplug jointer
-using a straight edge on the outfeed table adjust it so that when you turn the head (counter clockwise) the knives just touch the staight edge (NOTE** all the knives should touch the straight edge the same, if not your knives are not set correctly) This is your most important adjustment, if the outfeed is to high or to low it will cause inconsistant jointing.
-Now that the outfeed is trued up to the head you can adjust the infeed table, using the straight edge align it so that it is perfectly lined up with the outfeed table (not touching the kinives) Your jointer is now at ZERO
You can now adjust the infeed for depth of cut, Start by lowering the infeed a very small amount (1/16 of a inch to start)
The biggest problem I have seen is that people try to cut to much at one time, it will work alot better if you take several small cuts instead of one deep cut.
Also- getting the knives set perfectly in the head is a key to success, if this is not happening you WILL have jointing problems. ALSO if the knives are not sharp they will pull the material down causing snipe.
I really hope this helps and if you need a visual aid try looking it up on you tube.
I have used my jointer for numerous different projects, Here is a cool one for tapered table legs.
Take a piece of square stock (like 2x2 ) about 3 feet long, make a mark about 2 foot up and wrap a piece of tape around it at the mark.
now make a mark (we will call it a stop mark) on the fence of the jointer by the head.
with a pencil and number the edges on the 2x2 (above the tape so you dont joint them off)
turn on jointer and run side 1 until your tape is at the fence mark, carefully lift 2x2 and do the same to the 2 side.
only joint the #1 & #2 sides, run several more times and you will have a perfect tapered leg.
SHOP DOG
May 02, 2011 | Masonry Tools
When edge jointing I get a slight taper where the part of the board fed through last has less taken off than the front edge. It used to work just fine but I can't remember what i did to make it precise...
your outfeed table needs to be raised the amount of material you are removing to keep the board level through your pass. If your removing1/16" then your outfeed needs to be a 1/16" higher than the infeed.
Jan 14, 2010 | Grizzly Masonry Tools
Infeed table is not level with outfeed table. Can not find any adjustments for this. Can you Help?
I'm not familiar with hobby type machines like craftsman, but good shop jointers have levers or hand wheels for the infeed and out,either on the sides or the front. I hope your outfeed is the higher one. When jointing, the amount of stock material removed should be compensated by the hight of the outfeed table, otherwise you will produce a taper near the end of the board your jointing. Check and see if raising or lowering the knives moves the outfeed if you still can't find separate adjusters.
Jan 09, 2010 | Craftsman Masonry Tools
The infeed and outfeed tables on my DJ 20 are out of alignment
This is common on joiners due to moving of the machine by lifting it around by lifting it by the end of the infeed and outfeed tables. It causes the tables to be moved out of alignment due to the weight of the machine, it must be moved by the base or you always have this problem reoccur. Raise the infeed table so that a 6' to 8' straight edge will clear the cutter blades. At most automotive stores or machinery supply stores you can purchase shim kits (.0001" to .0015") you won't need much, the best because they are a hardened metal or stainless, you can use foil or hard paper in a pinch but it won't last. The outfeed table is only ment to adjust for the cutter height only. Under the out feed table are the wedge slides, loosen them as needed (not to loose) untill you can lift the table enough to slid in the needed shim, start with a .0005" shim. Put same size shim on both sides unless the table is out of level with the infeed table. The shim needs to only go in about an inch, not the entire lenght of the slide, this will raise the end of the table to bring it up. Retighten the wedge slides, pretty tight but not torqued. Check it with the straight edge to see how you did. You probably will have to repeat the process with other thickness shims till you get it right, unless you get lucky the first time. It took me two or three trys. The proof is when you get a straight edge on your wood. Have Fun!
May 31, 2009 | Delta X5 Dj20 8" Precision Jointer
Tapering
First, unplug the jointer, then, insure that all the cutters are set to the same height. Raise the outfeed table with a straight piece of wood or a framing square sitting on it and extending over the cutters. Each cutter should just touch the board without raising it. The infeed table is lowered by how deep you want to cut.
Always look at the grain of the board you are cutting. Never allow the cutters to strike grain that is running down into the cutters. It will chip out chunks of wood. The grain should be tapering down away from the cutters, back toward you, never toward them.
The tapering you mentioned usually happens when the outfeed table is lower than the cutter tops.
May 25, 2009 | Delta Machinery Masonry Tools
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Delta JT160 Shopmaster 10 Amp 6 Inch Benchtop Jointer Logo
458 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
