Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Electrical hookup installing new range hood. Black to black , white to white, and ground just touching the new hood. ground is not long enough to go through the hole where the black and white wires go Will not operate. Any ideas? Tested on old hood and all was working.
  • 653 Answers
If you have the hot and common wires connected (black to black and white to white) it should work. If not, try connecting a length of wire to the ground wire and connect to ground, such as a copper cold water pipe, radiator, heater vent, or the ground terminal in a nearby outlet. If it works then, you need to splice an extension to the ground wire to connect in the box where the hot and common are. Keep in mind all splices must be inside an approved box. If it still doesn't work, yours is not the first nor the last defective hood to be sold.
Posted on Feb 28, 2009
I have 4 cables to install to plug in,white,red,black and ground,I have indications for the white and ground and none for the white and black.where do they go?
YOU ARE DEALING WITH 220 VOLTS.
THE RED AND BLACK WIRES ARE EACH HOT WITH 110 VOLTS. THEY GO ON THE 2 MAIN TOP TERMINALS , THE WHITE IS THE COMMON AND IS THE BOTTOM TERMINAL,
THE GREEN (USUALLY) IS GROUND.
HAPPY COOKING AND THANKS FOR USING FIX-YA
Jan 05, 2011 | GE JDS26 Electric Kitchen Range
We had a drop in stove and we replaced it with a new slide in but when we took out the old stove it was hard wired in. Soi cut the wires, there were threea black, white and a soild copper so i installed a...
Oh my! The white and black are normally both HOT wires!!! Bare copper is ALWAYS a ground wire, and also can work as neutral. Neutral is the middle prong on the plug.
Turn off the breaker before even touching your appliance, there might be 110v on the metal parts!!!
Black and white should be on the sides, and bare copper - in the middle.
Before switching the wires make sure that black and white really are the hot wires: there should be 220-240v between them.
Oct 14, 2009 | GE Profile JB968 Electric Kitchen Range
Pacific range hood hass two and one green cord, wall has black, white and ground. Which black cord do I attach to the white?
It doesn't matter as long as the green is to ground. If you were powering multiple units in series it would be different, but in your case it doesnt matter.
Aug 24, 2009 | Kitchen Ranges
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
I need to know how to wire the plug into the back of the dryer
Current electrical codes require a 4 wire hookup for all dryers. There needs to be a separate ground and neutral. If you do not know how to hookup the 4 wire version, it is worth calling an electrician to install the correct wires. If there is a problem down the line, the improper installation will invalidate your insurance claim. Dan
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
May 26, 2009 | Jenn-Air 30 in. Pro-Style Range Hood
Wiring hookup
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Mar 01, 2008 | Miele Designer DA230-2 Kitchen Hood
Miele DA230-2
The latest DA230-3 hood is a 120V 15amp model and has a black/red wire to live, a white wire to neutral and a green to ground.
You may have a 220V model. I suggest to have a licensed electrician hard wire according to the voltage, load, and circuit rating listed on this data plate.
Dec 26, 2007 | Miele Designer DA230-2 Kitchen Hood
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
301 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
