Question about Uniden Bearcat Pro PC78LTW 40-Channels Base CB Radio
Can not transmit
My radio recieves, but when I push the key down to check my SWR or talk, the needle does not move. Every now and then the sound goes down where you can't hear, and then comes back on.
  • 22 Answers
You'd be suprised how much a bad mic can affect your radio. Start by trying a friends 4-pin mic, or grab a cheapo one and try it. If its not the mic, then its time for some SWR tuning, the manual tells you how to do that. Its a very simple process to do, and once you learn the steps you'll go right through it like you've been doing it forever. If your mic is good, First I'd check my coax for any kinks or breakage. Problem is a lot of times you may have a bad coax and there isn't even a kink or bend anywhere, I've seen brand new ones that were bad. Then the ground where the antenna is mounted. Can you tell me if your using a mag mount antenna or a bracket?
Posted on Mar 19, 2009
try blowing some canned air on the knob and switch to remove dust , also try a dash of electrical component spray on them , then see if it works.
May 06, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Receives fine, needle does not move on transmit, transmit light lights
Needle on the meter might have went out . Is it stuck in one spot? If it moves during receive and goes to zero when keyed it most likely the final.
Mar 08, 2015 | Radio Communications
Cobra 29 now Ltd classic Cobra 29 classic receives not well but does not transmit don't even move the swr./power meter any ideas
High SWR on antenna system.. may have mess up your RF final transistors. if you were talking on it for a long time. have someone check the SWR on the antenna system... should be a FREE service.
Jul 13, 2014 | Radio Communications
turn the SWR/CAL/S-RF switch and set it back to S-RF
Nov 17, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Radio transmits and recieves but is like squelch is turned way up and needle doesnt move at all
Check your antenna. Make sure it is getting a proper ground. If mag mount; make sure base of antenna and where you put it are both super clean. Check where whip goes into coil or base. Make sure all allen screws are tight and whip is not either all the way down to the base or up to the top. If antenna is mounted; make sure that it has a good ground. You might have to remove some paint around the base to get a good connection. DO NOT TRANSMIT WITH A HIGH SWR. YOU CAN BURN OUT THE EXPENSIVE POWER OUTPUT TRANSISTOR. Hope it helps.
Aug 16, 2011 | Cobra 29 LTD CB Radio
My radio is recieving a signal from other cber's but i don't think they can hear me
Go on a channel where people are talking and when some one stops transmitting key up and say, "breaker breaker, can I have a radio check please?"
that is how you call for a radio check to see if people can hear you.
breaker breaker, or break break means kind of like, "excuse me, I would like to talk on the channel please."
If they hear you the will most likey say, "its working." or "Checks in the mail." You can then ask them after that how the radio sounds.
Also make sure your mic gain is up.
If you get no response then there may be another problem. Make sure you followed the instructions that came with the radio on how to tune your antenna for best SWR. This is important.
Dec 08, 2009 | Cobra 19 DX IV CB Radio
I have a cobra 25 ltd and when i key the mic the gauge of the db barley goes up. is something wrong ? also the gauge says its measuring tx power what does that actually mean/ do
TX means transmit. There are 3 settings for the meter. The top one is to measure your TX/RX that's transmit and receive. CAL is to calibrate the meter to check your SWR.
Reasons your needle may not be moving much when you key while on TX/RX. The dynamic is probably all the way down. That is your mic gain. If you turn that up when you talk the needle will swing more. If the radio is stock and not modded, you can turn this all the way up and leave it.
Also there could be something wrong with the mic. If people can hear you then its not the mic.
If people can hear you fine when you transmit, it may just be a bad meter. Not a big problem, you will just need an external meter to make sure you swr is not high.this is important because if it is over 1.5 you run the risk of blowing the final transistor.
Oct 11, 2009 | Cobra 29 LTD CB Radio
Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Dec 11, 2008 | Midland Radio Communications
Uniden Bearcat Pro PC78LTW 40-Channels Base CB Radio Logo
113 people viewed this question
Top Uniden Radio Communications Experts
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
