Question about AEG Electrical Supplies
Lights and appliences dim
This is a 1978  generac 4kw generator that was used for 14 hrs. kept in pristine condition it started right up and ran everything i needed it to . after 3 hrs one by one it seemed that things were under powered. i shut them off. until it would barely run lights. im assuming its the voltage regulator. do you have any thoughts
thank you  scott
  • 169 Answers
If this is an XL4000 I first check on the condition of the brushes and slip rings, then look at the voltage regulator.
Regards,
Carl
Posted on Mar 01, 2009
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
I have a generac-guardian-7500 watt -propane generator on the front of my catering trailer. It ran fine and was running , but durning one festival we were doing it started sputtring and popping so we shut...
Well, Propane / LPG fuel are in a compressed liquid state in the bottle and have to decompress to a gaseous state before entering the engine.
If you have a bad regulator, liquid gas will make its way through the fuel line causing inconsistent levels of fuel to air mixtures.
All this can change based on the outside ambient temperature, since pressure and temperature are directly related. (The science behind air conditioning)
It sounds like your fuel mixture is running too rich and the engine is flooding with liquid gas that hasn't been vaporized. I can only speculate based on the limited information you've provided. If liquid gas found its way into the engine, that would describe the sputtering effect you describing.
Mar 31, 2017 | Electrical Supplies
I have an older model Niagara 4kw by generac with low hours. I started it recently for the first time in 3 years. It ran fine but produced no current. I checked the brushes and cleaned the slip rings but...
I have not seen yor generator in practice, but saw some pictures of it.
As it is an older model, but it is not rare for modern generators too, when they stay a lot of time (3 years is a good lot of time), they lose thier magnetism.
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
Jul 31, 2010 | Generac Electrical Supplies
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
Onan 4kw Emerald I generator will not crank
The gen. is not the problem, the engine start circuit is not functioning. You need to look at the starter solenoid and starter.
Jul 01, 2009 | Electronics - Others
Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Nov 09, 2008 | Electrical Supplies
Electrical Supplies Logo
115 people viewed this question
Top AEG Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an AEG Electrical Supply Expert? Answer questions, earn points and help others
