Question about Magnum DeltaForce CB Radio
Magnum Delta Force Radio: The schematic does not match what is on my work bench! Schematic shows 10 tact switches,there are eight on the unit. If I trace back the leads from the rotary frequency changer then they go to different pins on the micro processor than those shown on the diagram. I am only repairing this radio as a favour, I am not making any cash out of it so I may give up shortly (not like me, I usuallly find the fault!) There must be more than one "Version" of the Magnum Delta Force? How do I know what I've got? Where do I get a full schematic/ drawing?
  • 1 more comment
  • Jon Holloway Mar 13, 2009
    Hi, thanks for responding. The serial number on the back of the Magnum Delta Force radio that I am repairing is 02030099. The problem is in the system control, it will TX/RX perfectly but the micro does not change channels via the chan up/down knob. It looks like someone has played with it a bit (Ahh!) but I am used to repairing equipment that HAS to be repaired even if it takes WEEKS (My day job is testing and fault finding on things like electron microscope power supplies, costing £10,000+) It would make life easier if I had a proper schematic and layout for this Magnum radio. Cheers
  • Jon Holloway Mar 14, 2009
    Thanks for getting back to me. I already tried the schematic at cb tricks. If you trace back the connections from the switches in the switch matrix then some of them go to different pins on the micro processor. Also the numbers of the switches on the pcb do not match their functions on the diagram. The schematic shows two switches for up/down frequency change which are in parallel with the rotary chan knob, these do not exist on the unit I have! Perhaps there is more than one version of the Magnum Delta Force?
  • james morgan May 11, 2010
    WHAT IS THE PROBLEM WITH THE RADIO I CAN SEND A SCHEMATIC TO YOUR EMAIL ADDRESS I NEED TO KNOW THE SERIAL NUMBER ON THE REAR OF THE RADIO.
  • 40 Answers
Usualy that is a sign that someone was trying to get more channels then it already has which is imposible to get any mor ok check this web site cbtricks.com go to the radio information section go to m look for the magnum radio section look for the deta force you should find all you need there. good luck with your projec and god bless you.
james morgan
morgans electronics
Posted on Mar 13, 2009
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Based on the Delta Force Schematic and the Turner +2 diagram 1=White 2=Red 3=Black 4=No connection (Unless you install 2 scan buttons in the Turner +2) 5= Shield Switch the internal switch in the bottom of the microphone for Electronic Switching (Not Relay). :-)
Aug 24, 2014 | Radio Communications
Is there a diagram showing how to calibrate a magnum deltas force cb radio
I found it and so can you.Do a serch for magnum delta force radio. or go to www.bastardfairies.com
May 25, 2014 | Magnum DeltaForce CB Radio
I cant call or receive with my magnum delta force cb radio in the am settings please help
What antenna are you using? What is the SWR on the antenna? Note that the swr wont necessarily affect Transmit but it will show if there is a general antenna problem like a short, that could be causing this. Otherwise it is an issue that needs to be diagnosed in depth on a test bench.
Sep 14, 2013 | Magnum DeltaForce CB Radio
My magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
May 14, 2009 | Magnum DeltaForce CB Radio
Service manual
You may click this link for the service manual:
http://www.rigpix.com/cbfreeband/magnum_deltaforce_manual.pdf
Have a great day!
Apr 29, 2009 | Magnum DeltaForce CB Radio
Powering the Yaesu FT-11R
The battery select determines whether you're using a NiCd or Alkaline battery, I believe the "adjust" is used to put the radio into service mode. If there's not an "auxiliary power input" you can hook up the bench supply to, check the battery output for the voltages and polarities, and hook up your supply accordingly.
Dec 07, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Magnum delta force
What you saw smoke was the protection diode. I do not have one of these radios and have not worked on one yet, but most radios are the same where the protection diode is located on the pc board, one the components side, close to where the wire from the main power positive pin is soldered into the pc board.
I will have to do a little research to see if I can come up with the number of the diode. I have a couple of diagrams and a schematic from cbtricks.com. If I can not located it from their informaiton, I can contact my supplier Monday to see if he can tell me the number. If you happen to located the burnt diode before I come up with the information, please respond so I will know.
Dean Pitts
Rollin CBs
Nov 01, 2008 | Radio Communications
Radio Communications Logo
364 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
