Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door problem Hi, my wd63 washing machine will not run unless I put pressure at the top of the door. Would I be right in thinking there is a problem with the door sensor or seal? The machine is 5 years old.Thanks
  • kathpearson Mar 03, 2009
    Many thanks!!!! Sorted quite easily - even for a girl!!!
  • 566 Answers
Hi from the uk kath ? you correct in your diagnosis! and is a common problem as machine ages there is a micro switch/delay switch where the door latches ok? if you unplug power from machine then remove the top screws from rear panel (these also hold top panel ) then lift top panel and pull back slightly you can lift top off ?ok now look inside machine where door latches ? you should see the m/delay switch with an elec plug/wires attached ? unplug then undo the screws that secure the switch and lift out the prob with switch is because it is fibre/plastic it gets stiff due to wear/dust so use some wd40 and spray it all around the plunger of switch and work it manually by hand in/out you will know when it operates freely! then dry and refit switch and elec plug/wires (almost forgot !do all this with dooropen on machine sorry ) then reassemble panels and secure reconnect power put some washing in for testing then push door closed gently at the point where release handle is ? always close at this point ? select wash type then start ! your machine will/should start wash cycle ok ? if it does? then congratulations! you have saved $$$$s then when cycle has finished completely ! wait untill light goes off (this is the switch delay ) then you will find door opens easily ? hope this helps and inspires you ? any problems e mail back best wishes from the n/west uk
Posted on Feb 28, 2009
  • silver top Mar 03, 2009
    WHOSE A CLEVER GIRL THEN ?? well done ! saved a few bob or $$$s thanks for update very much appreciated ! hope instruction's were helpful? if you req any info on other diy or problems with autos you want to diy and save money no problem the impossible we can achieve but miracles take a little longer ? so always think the positive waves!best wishes from n/west uk
Machine runs wash cycle but fails to drain and spin. When door unlocks I remove and replace wet washing then switch on rinse and spin cycle. This seems to work but is no long term answer.
Hi, The washer will fail to spin if there is too much water in the machine, check the filter on the machine is not clogged or blocked if it's not then the pump could be suspect, normally you can hear it running on the spin cycle. it could also be the motor brushes are worn.
if its none of the above I would suggest that it maybe the pressure switch or pressure switch tube blocked other than that the last resort is the programmer or motor control panel.
Hope this helps.
Feb 09, 2011 | Hotpoint Aquarius WD63 Front Load...
My machine has the door lock light on and wont start, the door is locked as i have to press the release to open it!
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD63 Front Load...
How can I unscrew the drain outlet at the bottom front of my Hotpoint WT540? Our machine has completed a wash and drained, but isn't spinning. The door light flashes when I try and run a spin. I decided to...
Keep trying to unscrew it, as it should come right out for cleaning. A little water will come out too so put a small tray under the machine first.
Look at my other solutions, as for DOOR light flashing.
Apr 02, 2010 | Hotpoint Aquarius WD63 Front Load...
How do i remove rubber seal on hotpoint washing machine for getting in to door lock
No need to remove seal.
Remove top cover, undo 2 screws securing door lock. and reach down inside the washer to access the door lock.. This is the easy to do it.
Feb 04, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door locked light stays on so cannot open door
Make sure that all the water has drained or the door will not open, lay the hose into a bowl or other shallow vessel and let any remaining water run out. Wait a for a while for lock to release,if it still does not open then the door is going to have to be opened by force.
Plz rate this solution.
Thanks
Dec 16, 2008 | Hotpoint Aquarius WD63 Front Load...
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius plus WMA44
Will be blockage in sump hose .more info req. if this is not right
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine wont turn on
sounds llike the door interlock mechanism which will stop the poer coming on look up washing machine lock on ebay
steve
Sep 28, 2008 | Hotpoint Aquarius WD63 Front Load...
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
97 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
