Question about Brother MFC 420CN All-In-One InkJet Printer
Refilling my Yellow ink
Bought this new printer only made no more than 10 copies and told yellow ink was out and are unabl to make any copies. Went and bought a new yellow cartarige and installed it. Asked if installed yellow cartarige and pressed (1) for yes got a message "no cartarige". Repeated several times same result. Arrg.
    Sniper:
  • 113 Answers
what you want to ask?
yes sure you need to replace the cartarige.
Good Luck!!!
neo
Posted on Feb 28, 2009
  • nenotech_neo Feb 28, 2009
    ok......here is your solution......
    1) turn off and unplug
    2) Take out all cartridges, put all away inside a carton box!!! Important.
    3) Clean in side with acetone and inject some drop in side the hole on the bottom .that one is for the air replacement. The other male shape is the way ink goes to the injector. Don’t touch this one.
    4) Plug and turn on(with out any cartridge)
    5) Now you have message, black near empty, yellow, cyan, and magenta near empty.
    6) In menu, start cleaning all ink.
    7) When finish you have same message, don’t worry.
    8) Turn off (with out unplugging)
    9) Put cartridge back
    10) Turn on
    11) Let the machine do its job.
    12) In menu, choose –cleaning all cartridge.
    13) Information((( It take longer ,because machine should remove air which stuck in pipe when we have cleaned with out having cartridge)
    14) Almost finished.
    ** Remember if ink is dry in air pipe inside the place where cartridge install. You should clean it very well.
    ** make sure all cartridges are refilled or are new, or hase some inke inside.
    Good luck!!!
    If "NO CARTRIDGE" still remains on the LCD after verifying you areusinga new Genuine Brother ink cartridge and your machine is within
    warranty,you can locate a Brother Authorized Service Center (ASC) in
    your area orcontact Brother Customer Service by calling 1-877-Brother
    (1-877-276-8437) Monday through Friday, excluding holidays.
    Scholar:
  • 85 Answers
The cartridge gor dismantelled.this happens many times get the new cartridge replaced.
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
My yellow ink ran out and I finally replaced all inks this evening. Now, with all new inks, I keep getting a message that the yellow needs to be replaced. Any suggestions? I've turned off the printer,...
I had the same problem with mine but I bought a refill cartridge instead of a new one and went through three refilled cartridges when I found that it was that I needed a brand new one. For some reason, the HP printers and some other printers need to know that you are using the same brand of ink as the printer. if it is another brand it wont except it and it wont let you print anything! So make sure it is a brand new hp brand ;)
Nov 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Refilling ink cartridges
NVER EVER USE REFILLS ON BROTHER MACHINES, THE PRINT HEAD WILL GO BAD, I AM A SERVICE CENTER FOR BROTHER
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Jun 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
14 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
