Question about Life Fitness Remanufactured Next Generation Treadmill
Life fitness treadmill display: transistor error-won't run
Life Fitness 91Ti treadmill stopped and displays "Transistor Error" . Any help on fixing? Does this sound complex or a home fix job? Any help is appreciated. Thank you.
  • 83 Answers
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
Apr 01, 2014 | Life Fitness 91Ti Treadmill
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www.
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Stuck Key Error Message on Life Fitness F3
    Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
    May 03, 2010 | Life Fitness F3 Folding Treadmill with...
    Life Fitness Treadmill "FET" error
    Can you please provide model of unit.
    Feb 20, 2010 | Exercise & Fitness
    Error 1 message on older life fitness t3 treadmill
    Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
    Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
    Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
    I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
    FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
    Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
    FET Error
    FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
    Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
    Fet error message
    The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
    Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
    Life Fitness Remanufactured   Next Generation Treadmill Logo
    763 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
