Question about HP Photosmart 8250 InkJet Printer
How do I take a HP 8250 Photosmart Printer apart?
I'm trying to remove the battery from my HP 8250 Photosmart Printer, and I've already been able to remove the top tilt panel, by sliding it off of the two support tilt arms. Now, I'm trying to take the rest of the plastic covering off. I got as far as trying to take the side off by sliding a small screwdriver into those 6 slots that appear on either end on top of the printer, but the part I can't figure out is how to free up the rear and front parts of the grey plastic wrap around trim. In other words, freeing up the grey plastic wrap in the viscinity of the 6 slots wasn't a problem, although finding where to free the trim where it wraps both around the front and rear of the printer is a big problem.
Are there additional holes to free up these sections, or does the section somehow slide to free them up?
Is there a disassembly diagram which would show these sections in more close detail?
Thanks!
I have an HP Photosmart 8250. I changed the Magenta cartridge and it seemed to work fine for a while and now when I print, the Magenta fails to come out. I have a Purge test that is basically an entire...
please if you are not professional technician then don't do this.but you can use some cartridge head cleaning solution.on the print head.if problem not solve then replace the cartridge.
Jan 12, 2011 | HP Photosmart 8250 InkJet Printer
How do you remove paper tray on hp photosmart 8250 printer to clear paper jam
Hi we2halls,
You may want to try the procedure on this link to help you clear the "Paper Jam". It includes detailed instructions and some illustrations.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | HP Photosmart 8250 InkJet Printer
Suspect that the HP 8250 photosmart battery needs replaced. How to?
Hi
  • Check the battery light. If the light is red, recharge the battery.
  • If the battery light is still red after recharge, replace the battery.
Figure: Removing a battery (example only)
1 - Slide the battery release slider in the direction of the arrow
2 - Remove the battery
Regards
Riztech
Sep 26, 2010 | HP - HP Photosmart 8250 printer
HP photosmart 8250 is printing different margins
ok..do us a favor here..try a test page from printer selection panel. just to make sure it's not the printer..you may need to re install new printer drivers.
Nov 28, 2009 | HP Photosmart 8250 InkJet Printer
My HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: 4.1.1.00.1332 (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
May 09, 2009 | HP - HP Photosmart 8250 printer
Ink problem
I know this sounds silly but did you pull the blue tape off of the printer cartridge before you installed it? If you did, try removing it and installing it again. Maybe it was not aligned right. Also, there is a way in the HP printer software to instruct it that you installed a new cartridge - try that too.
Oct 03, 2008 | HP - HP Photosmart 8250 printer
8250 HP INK EXPIRED MESSAGE
I had same problem, and i solved it.
I opened my hp 8250 and removed it`s battery. It is located on left side of the printer, on the main board. You need to remove plastic covers , and then remove 3 screws holding board. You can move board just enough to get damn battery out of there. Now it works perfect!
I can send you some piccs if you need help.
Regards
Sasa
Sep 12, 2008 | HP - HP Photosmart 8250 printer
Photosmart 8250 printing computer codes
my printer photosmart 8250 is printing does not print it says ink system failure when i try to replace it the yellow ink jet so please please help i'm in third world country my email address is abrbw@yahoo.com please help again
Jul 17, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
739 people viewed this question
Seeker5211
Seeker5211
