Question about Toshiba Computers & Internet
How to open a Toshiba Satellite A215-S808 laptop
I have all the screws out, but something's still holding it together
    Scholar:
  • 150 Answers
I'm not entirely familiar with Toshiba, but check the display hinge, sometimes that needs to be pried off with a screwdriver first before it will come apart.
Basically, just look for anything that can be pried off without breaking.
Posted on Mar 01, 2009
My camera doesn't work on my Toshiba satellite A215-S7413
Please disconnect the cam and remove the cam software from the computer and re install the cam software and connect he device and check it.
Mar 17, 2012 | Lifetime Toshiba Satellite A215S7413...
My toshiba satellite a215-s7472 screen is very dim can hardly see anything what do I do too fix it I tried ajusting the light .
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
(Two present technologies being used)
The Toshiba Satellite A215-S7472 Notebook PC uses a CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm by 334mm. In inches that is;
Approximately a little thicker than 1/16th of an inch Thick, and a little over 13 inches Long)
A screen Inverter is used to convert the power (Electricity) from the laptop, for the Backlight, and LCD screen.
Point of all this?
90 PERCENT OF THE TIME the fault is a bad Inverter
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm
http://www.zkarlo.com/selected-zkarlo-part/inverter-board-p907.php
HOWEVER, the Backlight bulb is located inside the Screen Frame, of the LCD display assembly.
An LCD screen is composed of layers. These layers are held in a specific pattern, by the LCD screen frame.
This is a thin metal frame which surrounds the LCD screen layers, and has Philips head screws which hold the frame together.
NOTE*
The procedure is fairly intricate.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
For additional questions please post in a Comment.
Regards,
joecoolvette
[ So far I have only seen listings for the LCD screen itself, and not a separate CCFL Backlight ]
Feb 01, 2012 | Toshiba Computers & Internet
My toshiba satellite laptop keyboard just quit and won't work, totally frozen and nothing appears as i type. pls help toshiba satellite laptop A215-S5837, windows 7, vista
turn off your laptop by hold your power..ten turn on again and try to press f8 when it booting..go to safe mode and restore it by go to all program, accessories, system tools, and system restore
May 12, 2011 | Toshiba Satellite A215-S5837 Notebook
My toshiba laptop is askingn for a password to turn on. I know this relates to the cmos battery. I have the toshiba satellite A215-S7413, how to i get to the cmos battery?
How to get to the CMOS battery
The Toshiba Satellite A215-S4747 Notebook PC's CMOS battery, is soldered to a bracket on the bottom of the motherboard.
The laptop has to be completely disassembled to access it.
In this photo showing the bottom of the motherboard, the CMOS battery is in the middle,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-21.jpg
This is a link to a free Service Manual, detailing disassembly,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the 11th line down. The one that starts with Satellite A10
Go across and click on A215
This is a PDF file. It may take up to 30 seconds before you see the first page, and additional time to fully download.
Suggest you let the file download all the way before looking through it.
1) Remove ALL power to the laptop. Remove the AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
Suggest you bu and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
Average price is around $3 to $6.
3) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
There may be as many as 60 screws and 12 different types.
Do Not mix them up.
(You can use a clean egg carton in a pinch. Mark each egg holder)
Nov 26, 2010 | Toshiba Satellite A215-S4747 Notebook
How to replace keyboard on a toshiba sattelite A-215 laptop
Hi click on the link http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm , in your case i think you should just start at step:5 ,once you take out the screws be careful removing the plastic connecter they usually open "up"
Aug 28, 2010 | Toshiba Keyboard for Satellite A200 A215...
How to change dvd drive in toshiba satellite a215 s4807.
Flip the laptop over and look for a screw about 4" in from the face of the drive. somewhere towards the middle of the face. Pull this screw, eject the tray and give a sharp tug to the tray and it should slide out. If it doesn't do not continue to force it.
Jun 04, 2010 | Toshiba Satellite A215-S4807 Notebook
System failure of toshiba satellite a215-s7422
Put the laptop back together, its possible youve damaged one of the boards, and the "coin sounds" you hear are jsut beeps from the motherboard indication some form of system failure. call toshiba and see if you have any warranty coverage, and out of curiosity what did you drop on it? something heavy i presume?
Jan 24, 2009 | Toshiba Satellite A215-S7422 Notebook
Reset
It will be on the main board of laptop. You need to open the base and keyboard of laptop. Careful
May 21, 2008 | Toshiba Satellite A215-S5822 Laptop
Computers & Internet Logo
1,390 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
