Question about Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 vacuum that when light pressure is put on the handle it moves forward but in a jerky movement. Like the drive is engaging and disengaging. If you keep forward pressure on the handle the jerkiness does not happen. Is there an adjustment to correct this.
  • Kirby Expert
  • 324 Answers
I hope adjusting position of the position of the "pivot spring assembly" will help. but you may have to disassemble entire slide assembly to clean it up if it still does not work smoothly. See instructions HERE (adjustment is explained in step #6). Try to "play" with screws #4 and if it does not help - clean slid.
Good Luck
Posted on Mar 03, 2009
Kirby g5 self propels too fast
the slide has shifted forward slightly, this happens when the kirby
is hit against walls and skirting boards. you will need a service by your local kirby engineer. see for local agent
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Kirby g5d will not shift into drive
check tech drive sensor, where handle connects to main unit, but you need to open cover off and greese handle slider.
May 08, 2010 | Kirby G5 Bagged Upright Vacuum
When the power assistance drive to my G5 is engaged it is fixed in reverse.
I know the problem is not the tec-drive, it is the position on the handle piviot spring assy. no parts should be required to fix this issue. However a vacuum repair shop will be needed for this problem. I would find one that offers free estimates. might save ya some money.
Nov 18, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 gearbox clicks, why?
most of the time the small fork that comes off of the transmission and connects to the top slide wears out which doesnt allow the transmission to engage properly
Oct 10, 2009 | Kirby G5 Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Can't seem to pick up small items like lemon pips with Kirby G5. It just runs over them or pushes them backwards and forwards.
It sounds like your belt is broken, OR your beater bar is rotating but has not been adjusted downward to reach the carpet pile. Check by running the vacuum and looking to see if the beater is moving.
Jun 17, 2009 | Kirby G5 Bagged Upright Vacuum
G5 Kirby drive problem
You need to adjust your transmission. Here's a link that may help...
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
179 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
