Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My shark will not turn on.
I have had it plugged in for 20 minutes, I have also switched plug ins no luck. I noticed that I left some water in it last time. Could that have caused a problem?
  • Anonymous Mar 15, 2009
    I have the same problem. My light also does not come on.
  • GQadam May 20, 2009
    I plugged my mop in and used it just fine. I plugged it back in later in the day and the light wouldnt come on and it wouldnt work.
  • Euro-Pro Master
  • 43,501 Answers
That should not bother it...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
Posted on Sep 24, 2010
Red devil steam mop no steam coming out
Add CLR to water tank. Let it sit for an hr to overnight unplugged. Plug back in, turn on steam to medium setting and wait about 20 minutes. Mine started to steam and I let it steam for 5 min or so. Empty out CLR, add only "DISTILLED WATER" and clean away. Good luck.
Oct 24, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark s3501 plugged
I had same problem with no steam... ready to throw in the dumpster!
I tried to it take apart. (kind of hard) still ready to throw it!
Then I thought about CLR!
I put about 1/2 cup in, turned on and let set for about 20 to 30 minutes.
I really did not think this would work but... Amazing! I actually got STEAM!!!!!!
Next I dumped out what was left, put in distilled water and ran for another 30 minutes on high.
Will use CLR again before final clean out and 2 full tanks of distilled water before I use again.
May 27, 2012 | Vacuums
Just purchased the unit 2 weeks ago. Worked great. Last night I left it plugged into an outlet - but turned "off". This AM the unit comes on; timer showing default @ 5 minutes; however, no...
I wonder if you are talking about a coffee maker?
It ended up being listed under Vacuums!-
Sorry about that-- It sounds like you arehaving trouble getting the maker to boil water, and move it thru the maker, no?
Anyway-- I don't see why leaving it 'on' all night should have done anything wrong-
But maybe the Coffee maker guys know more about this repair than we do in Vacuums-
Sorry about that
Mack B
Jan 27, 2011 | Vacuums
Cleaning mr coffee ecm3 how
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have use my henry with no problem, tunred it off with the red switch on the top, 20 minutes later I went to use again but the machoine was toatlly dead with no power I have changed the plug fuse
Could be fault @ plug.. try cutting off 10 mm of cable then redo plug ..Replace fuse then try, if still dead try switch, you could short this out or if you have multimeter check for contact...if stii no action could be motor....
Nov 25, 2009 | Vacuums
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Model 1697.m Bissell carpet cleaner.
You are going to want to replace the water pump on the machine. Also you might want to look into replacing the belt that runs it. If that still des not working, you probably have a clog in the hose coming form the heater element. This is VERY common with the Bissells. Good Luck!
Jan 08, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Aug 31, 2007 | Black & Decker SV1000-4 SteamBuster Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
539 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
