Question about Freezers
Amps for an imperial freezer
We are trying to find out how many Amps that an Imperial HD commerical freezer Model#UL1647ECW1 has?
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Lost key to Imperial upright Freezer.
Hi, Thepart# 5303925437 is the whole lock key assembly. It appears this is the only way it is available and the caos is near $45.00.
I found where www.repairclinic.com has them in stock.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 19, 2009
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
I have an Imperial heavy duty freezer, model # UL2494ECW5. My door seal is ripped pretty good. Where could I purchase another rubber seal for that model?
The part number for that gasket is 216522312 it could be purchased from your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Sep 09, 2011 | Freezers
I have whirlpool imperial series refrigerator model et1lfkxkq03, which has freezer on top. Water from freezer is leaking into refrigerator. I cleared out the freezer and can't find the clogged drain.
You will probably have to remove the back panel, which is the evaporator cover. The defrost water drain is always at the base of the coil. **** the drain out and pour some hot water down it
Jun 22, 2011 | Whirlpool Freezers
I need an Imperial freezer gasket for model UL5000ECW4 serial WB01811931.
I have the same model number and my freezer completely defrosted and won' freeze. I assume I have a leek and all the freon (correct spelling) has leaked out any suggestions? My email is bjkirkland@gmail.com.
Mar 02, 2011 | Freezers
We have an upright Commercial Grade heavy duty Imperial Freezer, model # UL4000ECW2, purchased a little over 10 years ago. Today I noticed that everything in it is thawing and when I close it, it no longer...
the suction noise is not something that will happen all the time.
check the current draw on the compressor and make sure it is in between 1.2 and 1.6 amps.also look at you evaporator coils and make sure there is no excessive frost build up.If there is ice build up then you need to defrost it check the heating element and defrost timer and make sure they are in proper working order.also check the evaporator fan and make sure it is working when the unit is in a cooling mode.
Sep 07, 2010 | Freezers
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
I need to know which circuit to install for my freezer The description I have is imperial commercial manaual defrost freezer 20.7 Cu Ft.
put it on a dedicated circuit(meaning only item on this breaker) with a minimum of 20 amps @ 120 volts
Sep 23, 2009 | Freezers
Freezers Logo
181 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
