Question about Canon PIXMA MP780 All-In-One InkJet Printer
PIXMA MP780: Multiple pages feed together
Have had several years without any problems - now all of a sudden, from the rear paper feeed multiple pages feed through at the same time. First thought that the paper I was using was thinner than previous paper I had, so went back and inserted the older paper - same problem.
Even when the paper is just sitting in the vertical rear paper feed to go through, several pages are slipping down even when the printer is not in use.
Ideas?
Thanks!
  • 4 Answers
Most paper feeding in printers is done via rubber rollers. These rollers get dirty and over time, the dirt glazes on to the roller. When this happens, the roller loses its grip. If you look at the rollers they will actually look shiny. After a while the rubber will dry rot and it becomes a more frequent problem. Try the following:
(EASY/LIGHT CLEANING) Get some inkjet cleaning paper at you local office supply. This is usually a thick absorbent paper that you spray with a cleaner and "print" with the wet page.
(MEDIUM) If that fails, unplug the printer and try using rubbing alcohol or ammonia to rub the rollers with a terry cloth. Be sure to rotate the rollers and get them all the way around.
(HARDER/BE CAREFUL) For hard glazed dirt, you may want to carefully use an hobby knife to scrape it off the rollers, being carful not to damage the rollers. Follow up with alcohol cleaning described above.
Posted on Mar 05, 2009
What is adf
Hello!
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
It grabs several sheets of paper at one time
This is most likely a paper problem, the paper is basically sticking to the next sheet, Ensure the paper is stored in a cool dry place helps, dont load the paper with more than what you need for a couple of days and when loading the paper flick the pages to allow air between the pages
If this dosnt work try a different brand of paper
Sep 09, 2009 | Lexmark Optra E310 Laser Printer
Canon pixma mp780 auto feed does not print
You probably need a new printhead, but that problem cann also be caused by the purge or cleaning station not working properly. If you do a cleaning cycle with no carts. and the little pads in the printhead come back with no ink on them then the purge is working and you need a new printhead.
Aug 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer grabs multiple pages to print one. Prints in mostly green for color copies.
Go into the printer setup menu and change the paper type to default. If your using Microsoft Word, go to 'File" > "Printer">"Properties" , and change to "plain paper" or default.
The problem sounds like the printer is set to print photos which is a heavy paper type. The printer needs to be set for a standard weight paper.
Mar 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer not recognising that paper is loaded
Had this problem yesterday, then after downloading the manual you need to
switch feed (left hand side). There are two feeders in the rear and pull out tray
at front, very bottom.
Hope this helps !
Feb 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper feed
Have you tried a different brand of paper?. When choosing the paper try and select one which the sheets can slide easily over each other. I had loads of problems with multiple feeds and paper jams with a cheap paper. I then changed to a heavier 90gsm all in one paper from staples and have had no more problems since.(and i just chuck the paper in straight from the packet with no fanning etc)
Dec 15, 2008 | HP OfficeJet Pro k550 Printer
Feeds multiple sheets of paper at once
This usually happens when "paper dust" builds up on the take in rollers. Clean the rollers with cotton and alcohol.
Sep 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PC 1080 F ADF Problem
call canon for instructions on how to clean feed roller and ADF path; otherwise probably need new seperator pad and possibly paper feed roller
Aug 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
290 people viewed this question
old marine
old marine
