Question about Astatic 636L Noise Canceling Microphone Microphone
I need wiring drigram for a tristar 120
All the wires have came off.... need to know which wires go to which numbers.....
  • Anonymous Mar 11, 2009
    all wires came off were does they do which numbwer
Here is info your looking for-for a 636l to a tristar 120 -is as follows-1-audio, 2-shield&blue,3-black,4-red,yellow not connected.
Posted on Mar 08, 2009
I need a wire diagram for a model 120 Gem mixer-#1010203964? year 2010
Hi Patricia,
Go to this link for the machine manual pdf. On page nine, WIRING DIAGRAM - GEM120A-10.
http://www.fiestafoodservices.com/img/thermalservers/pdf/gem120a.pdf
Fare. Well. My Lady.
Jul 06, 2014 | General GEM 120 Mixer
How do i wire atv honda 1987 trx250x
Get a manual and buy all the color and gauge of wire you will need.also connect kit with male/ female connectors to ease taking her apart again . Wire drigram like map,, just follow and do one section at a time.did a 3cly 350 Kawasaki all blue wire,4hours.15years old.easier than it looks!
Jun 20, 2014 | ATVs
Hubbell wallpack lighting diagram needed
not sure what you need , if you know what model it is type it in and search for it, what is it you are trying to do? ,wire it , it has wires for 120 volts, to use the correct voltage -- 120 use the black wire, white wire, and green, black to load,or power, white to neutral, green to ground. hope this helps you
Oct 16, 2011 | Home
Have voltage to the Hayward Tristar pool pump but it won't run!
SOUNDS LIKE YOU HAVE A BAD BREAKER.. THIS IS A GRAVY FIX.. I SEE A VOLT METER IN YOUR FUTURE YES ITS ONE TO CHECK 230 V AC .. YOU LOCAL CAR PARTS STORE HAS THESE CHEAP .. ASK HOW TO USE IT AND YOUR OFF.. WHAT WE ARE LOOKING FOR IS 230 240v IN THAT RANGE ON THE 2 WIRES ON THE BACK OF THE MOTOR... OR EVEN THE TIMER.. NO?.....BREAKER NO? REPLACE BREAKER... BREAKER YES.. CHECK TIMER CONTACTS .. don't forget to prime your pump after a repair !!!!!!!!.. did i help ? well then please vote.. I got to get back to fix'n the pool pumps here in Florida ... Jay .. PPRG
Jul 08, 2010 | Hayward TRISTAR INGROUND POOL PUMP - 2 HP...
Trying to wire a 56 for a tristar 120. any ideas?
I think you are talking roadking 56, take the end of mike apart, you will need a 4 pin mike end,solder,steady hand,or small clip vise like I use,it takes just a little dab of solder for each wire,don,t over do it,trim each mike wire one eight inch back,slide the mike end on the cord,do not forget the plastic insulator,then solder the white (audio) to pin 1. then solder the shield and red together to pin 2,then solder the black (receive) wire to pin 3, then solder the blue (transmit) to pin 4. Then put it back together. ..hope this helps..
Mar 28, 2010 | Radio Communications
My oven shits off in the process of baking
I think you meant to say shuts off while Baking but you didnt post your make and model Number! Please let me know Brand Name and Model number it should be on back of Range or on side of oven door you may have element going bad or it could be in the microprogrmming control box.
Nov 19, 2009 | Kitchen Ranges
How many watts is a tristar 120?
A Tristar CB radio cannot legally exceed 4 watts of transmitting power.
You can add anetnnas in order to increas the "gain" to have the equivalent of much more transmit power.
Microphones aren't measured in watts.
The "impedence" (amount of resistance) is the important measure.
Sep 30, 2009 | Astatic 636L Noise Canceling Microphone...
My friend has a Tristar MG1 vacuum. The cord was
Chances are that there is the tiniest fray of one of the wires touching somewhere. Since you have already made a good repair with nuts and tape, feel the length of the cord for other bite marks where a puncture might short the cords. If you find such a site, **** the sheath lengthwise, tape the wires and replace them in the sheath, then tape the sheath closed.
Regards, --W/D--
Aug 10, 2009 | Tristar Vacuums
Astatic 636L Noise Canceling Microphone Microphone Logo
138 people viewed this question
Top Astatic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
