Question about Microsoft Xbox 360 Console
I put in any disk and it says reading and then it goes back to open tray i need help someone anyone give me the answer
  • runeess45
    runeess45 Mar 01, 2009
    Same as you said. I have it also. But I just clean the disk and it usually works. Sometimes you just have to clean it and put it back in. I'm not really sure why it does this.
  • 26 Answers
It might actually be cheaper to order a new drive on ebay. The Benq has this problem almost always. So the best option is to replace the drive. Less maintenance, and less risk of breaking the drive. Best option without a doubt. Unless you are on a short budget, it's best to just replace it with a new one.
Posted on Jul 18, 2009
    Novelist:
  • 174 Answers
It sounds like a samsung drive, they are more likely to have this sort of error. it could be either the laser that is on the way out or that the little drive belt has streched or weakened. either way its repairable and we can help you do this, if you want to try yourself i can point you in the right direction for some guides. we also do the repair via our website at www.fixmyconsole.co.uk
if the drive belt is the problem, you can buy a 19mm drive belt from maplins.com and they are just the right size for the job. simply take the drive apart and make sure the tray is out, the drive belt is underneath near the top and can be removed with a small screwdriver etc.
the laser can be repaired by installing a new one from ebay OR in some cases it can be cured by adjusting the 'pots' i do have a guide for this if needed.
Posted on Mar 01, 2009
The CD tray will not open after the "welcome"
I hope you already have found the answer, but, I have 20 some odd Tascams in the field and this is the training that I give my operators. When a defective CD is in the drive (or one that the unit thinks is defective) you can turn off the machine and let it power down. Then when you power it up keep pressing eject before it has a chance to read the disk. It will go into eject mode before it will go into diagnostic mode and when the disk is out the machine don't let it go back in. Most of the time the machine goes back to working like it should.
Jan 31, 2011 | Tascam CC-222mkIII CD Player / Recorder
When a disk goes in the tray it says reading for about 60 se then it says open tray. Xbox does not read disk.
Hi
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
http://gamingbox.wordpress.com
Sep 05, 2010 | Microsoft Xbox 360 Console
X box wont read disks
Your lens is dirty, very common and is considered routine maintenance.
3 ways to fix this.
1. Buy a CD cleaner, it is a cd that has little brushes on it that clean the lens as it spins. Can buy one for under $20
2. You will need a can of compressed air for electronics. Open up your cd tray and pull the power from your 360. Push the tray half way in and position the nozzle extender for the can of air right at the cd lens and give it a few blasts of air. It may take a few times to get the nozzle in the right place.
3. Disassemble your 360 (will void warranty) and take the DVD Drive out of it. After the drive is removed you can remove the cover to the drive and manually clean the lens. Put it all back together and you are back to playing games and reading disks.
Hope this helps you out.
Feb 05, 2010 | Microsoft Xbox 360 Console
Xbox Will Not Read Any Thing I Put in it
i had the same problem with my xbox, i actually picked it up free because of that, when i got it home i tried cleaning the tray with the cd with little brushes on the bottom and that didnt do any good. i had to manually open the xbox 360 and then open the tray aswell, you can see on youtube how to open a 360 properly, its actually very easy, and then you actually open the tray and clean the laser eye with a q-tip and rubbing alcohol, its a few t9 screws to remove the xbox from the case and then 4 small star screws to open the tray and clean it, put it back together and it will run asgood as the day you bought it
if you need more details repost on this with your questions and i will answer them all
--that goes for anybody who needs a hand with a 360, i brought mine back from the 3 red rings of death 4 times without having to pay a hefty microsoft repair bill, just 6.00 for a few things that i needed to redo a few chips on the motherboard, if you need help i will do my best to help you--
(wish i had someone to help me when me and my wife figured this out):D
Tyler
Jul 06, 2009 | Microsoft Xbox 360 Console
Red & green flashing lights
Microsoft knows this is a problem with the connection to the board from the power cable to the disk drive. They cannot repair soldered points to the board. neither can't anyone else. I have been loking for someone to repair mines. The point at which the power cable connects to the board is lose and disconnected at certain points. Pretty much if this is your problem you need a new console. If thats your problem.
Jun 03, 2009 | Microsoft Xbox 360 Console
READING DISC OPEN TRAY!!!!
I took a small coffee straw and put some liquid silicone in it and stuck it through the front disc tray carefully to the small engine in the back. Hold your finger over the back of the straw so that the liquid stays in until you are over the engine top.Then I put in a disc cleaning disc for about 10 sec and then put in saints row 2 and it hasn't said "open tray" for about two weeks and counting.....
Mar 28, 2009 | Microsoft Xbox 360 Console
360 disk tray
What I did was took apart my Xbox and put the disc tray back on the tracks, carefully lifting it over the circle thing in the middle. When I lay my Box down horizontally, it opens and closes fine.
Jul 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
