Question about Peg Perego Vespa Scooter
My brother's Vespa scooter fell over and won't start up again.
He's had this problem several times and it's really expensive to get fixed. He's had to pay the ealer to come and get it and it would be so much better if he knew how to fix it quickly himself. It always seems to be at the least convenient time and place... Anything he can try would be a big help as at least it would make him feel less helpless when it happens. Thanks. Carla.
    Problem Solver:
  • 16 Answers
If it falls over and wont start it just gets flooded.
Simply remove the spark plug (inspection panel is behind your feet) and leave it sit for a half hour or so. Use the kickstart every now and then (with the scooter turned off). The excess fuel will eveporate and when the sparkplug is replaced it will start up but it will be smokey for a few minutes. Just leave it sit idling for a while to clear out.
Posted on Aug 23, 2009
Vespa engine won't start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://modernvespa.com/forum/wiki--won-t-start-diagnosis-for-beginners
Scooter won start
Vespa 300 GTS Starting Problem
When the Vespa Won Start Scooter in the Sticks
Scooter Troubleshooting Scooter won start All about Scooters
Jan 14, 2014 | Vespa Motorcycles
Vespa P150X Piaggio won't start
i think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new onevespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-2.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Jan 03, 2013 | Peg Perego Vespa Scooter
2007 Vespa GT 200 starter engages when brake lever is pulled
Hi, Anonymous your right-hand control housing starter button has shorted out with the front brake light switch what you need is a wiring diagram that is in the back of your service manual if you can't find the first and best tool you ever bought for your Vespa, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Starting Vespa with brake lever
pressing brake to start the scoot issue
2007 vespa gt 200 wiring diagram Google Search
Vespa GT 200 Workshop Manual
VespaGT200
VESPA RALLY 200 Manual
Nov 23, 2017 | 2007 Vespa GT 200
Hi i have a t5 vespa classic and awas on a scooter run for charity when my back wheel locked up i knew that the piston rings had gone so i put it in the garage repair place they fitted a new cluch...
If you are seizing the engine, the problem could be related to several things:
1st: If you are running lean, the engine will seize. 2st: If your engine timming is too advanced, it will also seize (plug fires too early). 3rd: If your piston to cylinder gap is too narrow it will overheat and seize (sometimes in just about 2 miles).
Any of these could be causing your problem, but there is one last advice I would like to tell you. Two stroke engines rely on fuel+oil mixture to lube the cylinder/piston parts. Most times I see someone seize and engine it happens after an uphill when the descent starts and the pilot cuts throttle resulting in overheating the engine. If you cut the throttle you also cut the oil (because it goes mixed with the gasoline) and that can cause the engine to seize. My advice is to blip the throttle one in a while when on a descent.
Hope this helps and you wont get any more problems with your scooter :) Regards
Feb 15, 2011 | Peg Perego Vespa Scooter
1963 allstate 125 scooter will run like new than it won,t start even thought it's getting spark and gas
Hi! I assume your problem only applies when the engine is hot. This could be one of several things:
1 - bad seals 2 - broken engine body (heat expands it and lets air in / compression out) 3 - related to above, but happening on top end (cylinder/head)
All these are hard to fix at home, but there it could also be related to a carb problem... imagine your scooter is running too rich, it will run ok for the first kms, but after you stop and because the plug is dirty and/or the engine is flooded, it wont start anymore.
When this happened did you check the sparkplug look (is it dark? dry or oily?)
Hope this helps! Regards
Feb 08, 2011 | Peg Perego Vespa Scooter
My Vespa PX125 Disc loses power on the journey.
adjust air mixture screw at rear of carb tighten it first then loosen it 1& half turns give it a go
Apr 17, 2010 | Peg Perego Vespa Scooter
Trouble Starting VESPA
Check for bad gas -- water in gas , it is likely you have left the choke on.
Jun 02, 2009 | Peg Perego Vespa Scooter
Vespa cutting out after around 40secs of running
getting to much fuel apparently.But have never seen or heard of one of these.
Dec 22, 2008 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
861 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
