Jura Capresso Impressa S8 Coffee Maker, Espresso Machine
Problem for Jura Capresso Impressa S8 Coffee Maker, Espresso Machine
Jura Capresso C3000 keeps saying clean unit
By BillyP on Feb 28, 2009
I have run the clean process with the tablet 2 X , but the machine keeps beeping to be cleaned. I use brita filtered water & thought to decalcify the machine for the 1st time. Maybe that will help, but do you use the liquid that the manual says(durgol), or the decalc tablets Williams Sonoma says to use? Anyone else have their machine want to be cleaned over & over? Aftter 2 years, my Jura Capresso S8 has just developed the same problem. I use the Claris filters, so I doubt it is a problem with calcification. The time before this, it made me clean it twice and then the message went away, not it keeps saying "Clean Unit" no matter what I try.
Comments:
Feb 28, 2009
- Called tech support, and here is what fixed my S8: 1. Turn off the machine. 2. Remove the tray. 3. Reach into the machine to the left of the flap, and reach up into the machine until you find a round disk with a screw in the middle. this is the tamping disk. 4. Clean the tamping disk with dry paper towels. 5. Put the tray back and turn the machine on. 6. Run a cleaning cycle without the cleaning tablet. This made the "Clean Unit" message on my machine go away, but tech support said if this did not work, you shoud 7. Unplug the machine for at least 2 hours, and that should reset the message. Hope that works for you!
Popular Solutions for Jura Capresso Impressa S8
Questions and Unsolved Problems for Jura Capresso Impressa S8
Do you recommend Jura Capresso Impressa S8 Coffee Maker, Espresso Machine?
Answer
Answer
My S8 was off for about 2 years! Now I can't get the water to go through the coffee mode. I do get... (More)
Answer
I have an Jura Impressa S8 and the coffee it produces has always had a slightly oily flavor (a... (More)
Answer
I have to fill the system ,because I was some time away. I Filled the water tank. Then I pressed... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and Espresso Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
