Question about KWorld PC to TV (0872880887527) Video Capture
PC to TV converter only shows color bars on TV screen
Have Kworld pc to tv converter running to analog 27" magnavox tv
Only get color bars....no picture
  • dtvengineer May 22, 2009
    KW-PCTV
    Stuck in color bars.
  • Tim Crosslin May 11, 2010
    What is the KWorld model number?
5 Suggested Answers
SOURCE: KWorld PC to TV Converter
there is none
Posted on Jan 28, 2008
SeanTech
  • 33 Answers
SOURCE: Kworld pc to TV - avi does not show on TV screen
This turned out to be due to weirdness in my laptop's onboard graphics card. If I set the external monitor to display the way an external monitor usually does, as a clone of the laptop screen, the videos show up blank. But if I set it as dual-screen (extend my desktop to this monitor) and drag the video app onto the second monitor, it works fine.
Posted on Jan 08, 2009
edisonfrelan
  • 113 Answers
SOURCE: driver and multimedia center
Hi!
try downloading your driver on these website www.driver.com
have a nice day
Posted on Apr 17, 2009
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Posted on May 27, 2009
SOURCE: No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Posted on Jul 10, 2009
Picture while booting up, lost when home is loaded
The PC to TV converter is not setup for the correct conversion. When PC's start up, they use 800x600 screens which is close to TV standard, and they can synch. If the PC is set for a much higher resolution for a monitor, it is too far off to display. Check the converter. Or set the display settings to 800x600.
Oct 08, 2009 | KWorld PC to TV (0872880887527) Video...
I just connected my new Kworld PC/TV converter. My tv now displays large vertical color lines. I,ve connected the yellow video cable, s-video cable and the red/green/blue cable. I have a new Toshiba...
Hi and welcome to FixYa,
Initially, a couple of checks:
  • verify that the P/N switch is set to the color system of your country. N (NTSC) for US and P for most of Euroope and Australia;
  • depending on how "old" the TV, the Screen Resolution of the Toshiba may have to be brought down to the lowest possible setting;
  • additionally, the Screen Refresh Rate may likewise need to be lowered say 60 Hz;
  • all of the connections you mentioned are video connections. However, only 1 should be used. You may have to experiment (again depending on the TV) which setting & connection would give you the best picture;
  • offhand, the component connection (if applicable, the red/green/blue cable) would give the best connection followed by S-Video and last would be yellow (composite).
Please postback results of initial checks.
Good luck and thank you for asking FixYa.
Aug 07, 2009 | KWorld PC to TV (0872880887527) Video...
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
TRying to get my PC to TV converter up and running
I just purchased the Kworld 1600 PC to TV Game Box today. I also had the same problem as many others seem to have had. The TV screen displayed only colored bars. After searching on line for troubleshooting ideas I finally was able to correct the problem, thanks to help of people responding to these problems on "FixYa", and I thank you, as I was ready to return the product at a loss of 15% of the cost (restocking fee).
I am using a Toshiba Satelite L350D with Vista Home Premium and a 2005-32"JVC TV.
First ensure that the Monitor Y-cable supplied has been properly installed to your PC and your TV (my first mistake). Each plug is individually identified, that being, TV, monitor, scan cnvtr.
Second, on Vista go to Control Panel, open (Double left click) the personalization icon. You can then open your display settings.click on advanced settings, this will open a window for your graphics card. Click on "List All Modes", use an 800 x 600 High Color Mode, 16 bit, 59 or 60 hertz, hit 'OK' and that window will close.Then hit 'Apply' in the Graphics Card window(the screen will go black and then set itself to the new mode). You may have to try a few different 800 x 600 modes to find the best one for your TV.
Thirdly this converter is only for video, not audio.
For audio you must use a 1/8 stereo plug from your PC headphone jack to an RCA adapter into the Left and Right Audio Input of your TV.
Make sure you are using the same Video Input Section for both your audio and video (Video1, Video2, Video3, you cannot plug the video into Video1 and the audio into Video2).
After setting this converter up on my Laptop I was also able to plug it into my 7+ year old desktop (Cicero P4, XP Home Edition).
I hope grouping these 3 problems into 1 will help others and save them some time and frustration.
Thanks again to everyone on "FixYa" for their help.
Mar 14, 2009 | KWorld PC to TV (0872880887527) Video...
Jan 07, 2009 | KWorld PC to TV (0872880887527) Video...
TB100MW9 DTV DIGITAL TO ANALOG CONVERTER
I assume you are attempting to connect another device to the set.
Selection of the output channel is normally accomplished from the external device, not the set.
Jun 30, 2008 | Philips Magnavox 27MS343S 27" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
KWorld PC to TV (0872880887527) Video Capture Logo
522 people viewed this question
Top KWorld Televison & Video Experts
Brian Sullivan
Brian Sullivan
sonic boom...
sonic boom...
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
