By man1 - usenet poster
I've seen a number of these portable DVD players on eBay and was wondering
how to make them region-free. I know that you can purchase them that way,
but I'd like to know how to do it in case a warranty repair is needed and
Lasonic "repairs" it back to normal.
Does anyone have any feedback on this player in general?
Thanks in advance.
Dan
Solution #1
posted on Aug 02, 2007
Odud - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Dan, I'd like to correct my previous message about having to re-enter the
region select code everytime I play a region 2 DVD. It doesn't work. I
had to play with the discs a few more times to figure out what I did.
Here's what you do if your DVD has audio problems:
1. Open the tray and put in the DVD
2. Press SETUP to bring up the settings menu
3. Close the tray and let the DVD spin for a few seconds (to load the
table of contents and region code, I would guess)
4. Press SETUP to turn off the settings menu and the DVD will start to play
and the audio problem should be gone.
I tried it on a lot of my region 2 DVDs and it works everytime!
- Hydroxy
- Hydroxy
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Janice - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Dan, I found Lasonic codes on # and while I passed them by
before because they looked like the same ones on other sites, the
instructions had more detail and I managed to figure out the code. Here it
is :)
1. Open tray
2. Press SETUP
3. Press VOL+
4. Press VOL-
5. Press VOL+
6. Press VOL-
7. The region code select screen will appear.
Use the blue arrows on the remote to select.
NOTE: Select '255' to play all regions
8. Press SETUP to save the setting and you can play the DVD
When I first got the player, my Japan region 2 DVDs would play the audio
incorrectly. Some DVDs had no audio, others had only the left channel.
When I first got the code to work, the first Japan DVD I tried had correct
sound. The next disc had no sound. I did find out how to correct this,
though. Everytime you open the tray to insert a region 2 DVD, do the
region select code and select the '255' code, and then the DVD plays fine.
I'm all set, I hope you enjoy the player when you get it, Dan!
- Hydroxy :)
is :)
1. Open tray
2. Press SETUP
3. Press VOL+
4. Press VOL-
5. Press VOL+
6. Press VOL-
- Hydroxy :)
Solution #4
Phoebe - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Dan, I don't have any PAL discs to try, but when I switch to PAL mode, the
screen flickers and scrolls for a split second, then it adjusts and the
screen looks fine. I suspect PAL videos should work OK. I didn't think
about it before, but I'll try making a short PAL VCD or SVCD and run it
through the player. I'll let you know how it goes tonight :)
About that website with the review, thanks for pointing it out! I'll try
emailing the reviewer for the code, didn't think of that. I'll post the
URL as soon as I dig it up.
Great to hear you ordered the player, it seems to be a great buy all around
- Hydroxy
- Hydroxy
Solution #5
Bray - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Thanks very much for the info.
Too bad about the reset, though. It DOES however tell us that it is a
simple hack via the remote, and not a hardware/firmware modification. Can
you send it back as "defective"?
I did ask the seller about the modification, and he claimed that it was
done in house by "someone", but not him. I did go ahead and order one, and
hope that it works well.
Question: how well does the PAL/NTSC conversion work? There are a few
DVD's from the UK that I'd like to get (R2 as well, aren't they)
No codes included in mine either. I did a major search of the Internet for
the hack and haven't turned up anything either. Too bad you can't remember
the review site- we could email the author.
Please keep us posted. I'll post if I find out anything. I can't believe
that nobody else had the 'reset defaults' problem.
Dan
Dan
Solution #6
Putty - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Dan, I bought the Lasonic DVD-8090 off of eBay. It was region-free when
I got it. Here's my results:
- Plays region 1 and region 3 (Hong Kong) DVDs just fine
- MP3s, Audio CDs, Super VideoCDs, and VideoCDs play fine
Drawbacks:
- My Japan region 2 DVDs had audio problems. Some would play the left
channel only, and others had no audio.
- No Fast-forward on the player itself, so when you listen to audio and
MP3 CDs you need the remote control to change songs.
Since the player was set as region-free, I thought I could try setting it
specifically to region 2 so I could test my Japan DVDs. I couldn't get
any of the Lasonic hack codes off the web to work with this player, and I
accidentally selected 'reset defaults' in the setup menu. Now my player
is back to manufacturer settings and can only play region 1 DVDs. I'm
waiting on the hack code to surface.
Other than not knowing the hack code, and that region 2 DVDs have audio
glitches, all the other features work just fine. For the price (I paid
$112.00 including shipping) I don't regret buying it.
If you decide on buying it, you could email the seller and ask for the
hack code. I read a review of the player on the web somewhere and the
person stated that his player came with a sheet containing the codes.
Mine didn't and the seller is not responding to my emails concerning the
code. Oh, well!
Good luck on your decision :)
- Hydroxy
Drawbacks:
code. Oh, well!
- Hydroxy
Suggest a new solution for this problem
Post a New problem for Lasonic DVD-8090 Portable DVD Player
Email this problem
Email this problem
Can you Help with these DVD Players problems?
Repair Service
Find DVD Player Repairman Near You:
