Question about Nintendo Activsion Guitar Hero® World Tour 2-Player Wireless Bundle for Wii
Need a wiring diagram for guitar hero microphone pc board
I ripped the wires off of the board in the microphone cable and i need to know which color wire gets soldered where.There are 4 colors .
3 Suggested Answers
SOURCE: how to solder guitar hero drum set wire
Thank you!
Posted on May 22, 2009
  • 11 Answers
SOURCE: Microphone won't work
Do you realize that you need a wii controller to be logged in for you to be in use of the controller?
Just log it in (unplugged) and plug the mic into the USB slot at the back of the wii.
Hope this helped!
Posted on May 31, 2009
Creative 9 pin male din damaged
The only way to go is Replace the 9 pin adapter. Radio Shack may have the adapter, check them out. You will need to be observant when locating the proper colored wire corresponding with each pin. Two ways to do this and all require a soldering iron. Either split or open the cover on the 9 pin male adapter and expose the wires going to each pin. Identify the colors and pin numbers and draw a diagram on paper to keep for reattaching the wires later on. Cut 1/4 of the insulation back from the end of each wire and tin the wires. In short, hold the solder to the wire ends and heat with the iron so a flow of solder runs along the bare wire. Make certain to put a connector cover onto the wires prior to soldering each wire in place on the pin end. Simply set the correct colored wire end in the proper pin number, hold the iron to the pin back end and allow the wire to affix itself. Do this with all wires. If you do not have 9 wires, that is not unusual, just do the procedure with what wires are available. If you cannot get the outer jacket off of the current 9 pin connecter, then you will need a Volt/Amp meter. Here you simply cut the wire approximately 1/2 to 2/4 Inch back from the cable 9 pin adapter, and locate the pin that corresponds to the colored wire. Using the RESISTANCE part of a meter, when you touch the two probes together the needle moves on the scale. Touch one end to a pin and try each colored wire end until you see the movement on the scale. Now you know what color corresponds with each pin. Solder each colored wire as mentioned above.
Dec 15, 2013 | Creative Technology SBS A200 2 Speakers
IPod Shuffle 2nd & 3rd gen Sync cable
save up to $50, make a sync cable for ipod shuffle 2nd gen and 3rd gen on your own,
all you need is a 4 poles 3.5 mm jack, and USB plug. you get this on an old USB connectors ,
the color coding of USB cables is in standard so all you have to do is to solder the color coded wire to the 3.5 mm jack
here are the links of pictures of wire color coding that tells where the wire shouuld be solder
on Dec 31, 2009 | Audio Players & Recorders
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
PR20 mic has three colored cables inside.. red black and yellow. the yellow has lost its solder. despite this it still works. what does the yellow cable do, and which prong inside should i re-solder it to?
Two of the wires are signal (1 is + the other is -). The third wire is ground. The two signal wires will go to either side of the mic diaphragm. (looks like a miniature speaker). The ground wire will usually go to the mic body. The colors could be proprietary to Heil so I'm not sure what they are based solely on color. If it's an "active" mic with an internal circuit board then there is no telling.
Typically the red and yellow would be the signal wires, the black would be the ground, however, as previously stated, this can not be guaranteed if Heil uses a proprietary setup.
Aug 23, 2011 | Heil Sound PR20 Professional Microphone
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
PXC250 headphone cable ripped out from electronics box
here is the schematic showing where the wires go. the thick copper is the copper that goes around the rest of the wires. it is not neat like the other wires, but lots of single strands. if you are missing some wires, cut 3 centimeter or so of the lead, the wires missing are probably broken further up the lead.
Getting the solder to wet these wires are notoriously difficult. For me the flux inside the solderingwire was not helping, so i took a match, burned of the lacquer of the end 5mm of each wire, scraped the soot of with a knife, and put flux from a box onto the wire. Then i got the solder to wet the wire. Do this with all the ends of the loose wires. Then solder them to the green board as instructed on the the schematic (it is the top of the two drawings that you want to use).
Be careful not to overheat the PCB. make the solder wet the fire first, then solder the wire to the PCB (green board)
Aug 15, 2009 | Sennheiser PXC 250 Consumer Headphones
Nintendo Activsion Guitar Hero® World Tour 2-Player Wireless Bundle  for  Wii Logo
567 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
