Question about Sony STR-DE945 Receiver
Blows bothe fuses on power supply bd. b- shorted
My sony blows both fuses on the power supply bd (the one with 2 fuses two small caps and two large caps). I found that the B- voltage was shorting. This lead to finding that the two CENTER CHANNEL power transistors had two legs shorted together (center and right). I unsolderded them an smoked a 22mf 100V cap beside the conector on the main bd where B- and B+ come in. I need to find out where to order the tranistors or a substute part number. The number on them are SK B2560 AND SK B1647. There is also a nimber on the bottom (010). Thanks
  • 336 Answers
The transistors you need are 2SD2560 and 2SB1647. (either you miss-read the D for a B or it was a typo) You can get them at: www.mcmelectronic.com
2S is a prefix on all Japanese transistors.
The 010 is a date code
Also check for open resistors from the base of those transistors and the dual emitter resistor (large white three leg resistor .22ohm)
Posted on Mar 01, 2009
SONY BDV-E280 BLOWING FUSES
I have not worked on these directly but it sounds like a bad capacitor in the power supply that blows fuses upon a power on. If the unit has a switch mode power supply the switch on from the strip might be sending in a high transient causing the switch mode supply to draw too much current. How does the unit work if you just leave it plugged in?
If switching these on and off the better way would be through a zero crossing voltage solid state switch.
Oct 05, 2012 | Sony BDVE280 3D Blu-ray Home Theater...
Input fuse blows on switch on
In most power supplies, if the input fuse blows that fast it's because of some shorted component right at the AC input. Check for shorted rectifier diodes and filter capacitors. Both are common failures, especially if the equipment has been subjected to power line surges. If the power supply checks out OK, shorted output devices in the amplifier section is the next most likely cause. Check for low resistance on the outputs of the power supply. It's helpful to have a schematic diagram of the receiver for troubleshooting, and you can often service manuals or other information free or at reasonable prices on the Internet.
Jun 25, 2011 | Cambridge Audio Audio Players & Recorders
Have a Sony STR-DE635 that keeps blowing the 2 8 amp fuses in the power supply. disconnected all speakers and powered up with same result. Checked bridge rectifier and (2) 10000 uf caps all are good
Have you checked the rails to ground for shorts. Get hold of a variac as it does make things a lot easier.
Sound like you might have some shorted output devices.
Hope this helps
Thanks for using FixYa
Aug 18, 2010 | Sony STR-DE835 Receiver
Flashing protector
This usually means an output transistor is shorted and the amp is protecting itself. There are usually 2 8 amp fuses GMA type (glass tube) that are located near the large transformer on the main board that also get blown. You can try the fuses and see if it fixes it (10% of the time it will). If they blow again, it will be one or more output transistors are shorted, and the unit will need professional repair.
Jun 13, 2009 | Sony STR-DE435 Receiver
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
Main power fuse blows on my sansui g-5700
my Sansui G-5700 blew a fuse (i think)...where can you find fuses for this thing?
Apr 29, 2008 | Audio Players & Recorders
Power
1. Make sure the AC outlet is good.
2. Make sure there is no damage to the AC line cord.
3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts4.gif store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Please let me know if I can be of further assistance to you.
- Jim
Mar 19, 2008 | Onkyo TX-SR601 Receiver
Reciever
Did you try unplugging the unit and taking the cover off and seeing if the internal fuse is blown? There maybe a fuseholder on the rear of the receiver too. It is usually black, 1/2" in diameter, with a twist off cap and the marking of the fuse rating in white. If not, you'll have to take the cover off and look for a blown internal fuse. If the fuse isn't blown, you could have a faulty on/off switch or power supply. If you replace the fuse and it blows again, then something has failed and is drawing too much current and causing the fuse to blow. It could be a bad power supply or a shorted audio output module. If that is the case, it will need to be taken to a shop to be serviced.
Let me know if I can be of further assistance to you.
- Jim
Feb 07, 2008 | Audio Players & Recorders
Fuse keep blowing off
If the fuse keeps blowing, that is an indication that something has failed and is drawing too much current. Most likely it could be a problem with the power supply, such as a shorted rectifier diode or voltage regulator. Another possibility could be a shorted audio output module. Unfortunately, you'll have to take it to a repair center to be serviced.
Please let me know if I can help you further.
- Jim
Feb 01, 2008 | Sony STR-DE345 Receiver
Sony STR-DE945 Receiver Logo
188 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
