Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini Electric MER6770AAC
The right front dual elemnt is not working properly. Only the inside aspect of the element heats up and not the outside aspect of the element. Suggestions?
  • 1 more comment
  • Bodhi Mar 01, 2009
    Maytag Gemini Electric MER6875BAS front right inside heating element is not working. Only the outside heating element is working.
    Maytag Gemini Electric MER6875BAS right front inside heating element is not working. The outside heating element heats up but the inside heating element will not.
  • Anonymous Mar 02, 2009
    Mine is the same problem, but the opposite element.  My right front inner element works, but not the outer element on the stove top.
I originally posted this problem March 1, 2009 as Bodhi58 and recently had the problem fixed. It turned out the burner needed to be replaced as the wire was split in the burner. The part alone was $210 but the service charge.
Posted on Apr 23, 2010
Should the lower oven heating element heat all the way around? The heating element in my oven only heats and glows red on the front and two sides, The rear part of the element never glows red.
This is probably normal. the element has a fine wire inside the tube that you see and depending on where it starts in the tube it will start glowing from there.
Nov 15, 2014 | Maytag MER6872BAS Gemini Electric Kitchen...
Electric burner does not heat up.
The reason for Maytag electric burner not to heat up is that the heating element had exploded and there was white powder all over the inside of the oven. Replacing the heating element will make it work.
Also would recommend having the following cross verified:
· Element terminals have loose connections? Reposition the element.
· Range element shorted out? Find out by testing; replace if needed.
· Burner switch is bad? Find out by testing; replace if needed.
· Element receptacle bad?
Thank You for using Fixya.com
Jul 28, 2009 | Maytag Gemini® MER6765BA Electric Kitchen...
One burner does not work. The outer burner works, but smaller inside one gets no power. It is only 2 years old
I called Maytag and even though my warranty had expired, they offered to fix it for free. What a nice thing to do!!
Oct 08, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag 500 electric smoothtop
lower elemnet in lower or upper oven??, should be an expused elemnt 2 screws on back wall of cavity should remove it forreplacemnt.TURN OFF POWER FIRST it is LIVE!!!!!!!!!!!
Feb 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Gemini MER6769BAW Range/Dual Ovens
depending on type of unit. most of the time they are very easy to change out.. look at element locate two screws. go shut off breaker to oven.. make sure its has no power. after removing screws element should come out fairly easy.. make sure not to let wires fall back inside unit. if so not to worry. just pull unit out from wall and remove back panel. push wire back through. hope this helps
Feb 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
340 people viewed this question
Top Maytag Kitchen Ranges Experts
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
