Question about KitchenAid KESC300 Electric Kitchen Range
F2eo error code electric kitchenaid range stuck key
Oven won't turn on.
  • Anonymous Apr 20, 2009
    I HAVE THE SAME PROBLEM AS MENTIONED ABOVE F2EO ERROR STUCK KEY
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Posted on Sep 05, 2007
SOURCE: Kitchenaid glass top electric range
That error code is for the "open oven sensor". You probably just need a new sensor.
Posted on Jun 07, 2007
SOURCE: Error
f2eo stuck key sign
Posted on Dec 22, 2008
  • 1214 Answers
SOURCE: KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Posted on Jan 29, 2009
  • 55 Answers
SOURCE: range has error of stuck key
need to replace touch pad not cheat
Posted on Jun 23, 2009
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | KitchenAid Kitchen Ranges
Have error message F2EO,oven not working
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
Nov 21, 2010 | KitchenAid KESC307 Electric Kitchen Range
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Error
f2eo stuck key sign
Mar 26, 2008 | KitchenAid Kitchen Ranges
Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Mar 20, 2008 | Kitchen Ranges
Oven not working
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
1,175 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
