Question about SanDisk Sansa Clip MP3 Player
It won't go away from refresh database
I was loading some music onto the sansa clip and i thought i'd finished so i took it out but now it won't do anything not even turn off it just stays on refresh database
  • 8,596 Answers
Format the player from within the player itself - the diretions are in the user's manual.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
The sansa clip got stuck on
try contacting sandisk or something and ask them
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Refresh database loop
SCREN LOAD MAIN IMAGE FAILED SWITH TO RECOVERY MODE
WHAT HAVE ?
Sep 24, 2008 | SanDisk Sansa e250 MP3 Player
(e260R) Refresh Database eternal loop
Turn it on into recovery mode (Hold + Record Button + Power)
Connect to computer (You should detect a 16MB drive)
Make an empty text file inside the 16MB Drive and rename it to "sansa.fmt"
Unplug the Sansa. You should see now a "Formatting..." on the Sansa's screen.
Sansa fixed!
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Refresh database
it's supposed to refresh database anytime you make changes to your clip. also, check in the settings what usb mode you're in as well as "my computer" to see if the device shows up when it's plugged in. as for transfering media, if you want to use a program to do it for you, use mtp (under settings on your clip). if you want to manually drag and drop, put it in msc (also in settings). also in msc, it doesn't really matter where you decide to drop the files onto the player, although there should already be a music folder to help keep things organized.
Jul 10, 2008 | SanDisk Sansa Clip MP3 Player
Refresh database
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Jan 19, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa Clip MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
