Question about HTC Tilt 8900 Smartphone
HTC Tilt (Trouble Reading SIM Card)
When I put my SIM card in it just says sim card is missing. Sometimes it will recognize it, sometimes it won't.
  • Anonymous Mar 12, 2009
    my htc tilt wont read my sim card, but my blackberry bold will...
    Problem Solver:
  • 16 Answers
Clean the contacts on the sim card
Posted on Mar 04, 2009
I have an unlock code for my HTC Tilt 8925, but when I put in my Net10 sim card to unlock the phone, it doesn't recognize there is a sim card inserted. is there a way around this?
i think your phone is locked to your provider. you need to unlock it to use it with other provider, you can unlock it using codes. codes are safe and simpler way in unlocking a phone. i unlocked my phone through codes from this site. WickedUnlock.com check it out.
Jun 09, 2011 | HTC Tilt 8900 Smartphone
I have problem with my htc touch diamond its showing sim card missing error
Hi there, Sometimes a SIM card can come loose in the back of the phone. Take off the back of the phone and take out the battery. Locate the SIM card. It's normally white and rectangle. Pull it out and then push it back and and make sure it is tight. Put the battery back in and let it boot up and see what happens. If it doesn't work, it sounds like you need a new SIM card, so you will have to go to your carrier.
Jun 06, 2011 | HTC Touch Diamond Smartphone
"Sim Card is Missing"
This is not a big issue, what you need to do is to just upgrade the OS of your handset, actually your current OS is corrupt either due to some malfunctioning or due to some file you have tried to download from the web. Just simply check the latest OS available and replace it with your current one. I hope your issue will be resolved after doing this.
Feb 21, 2010 | HTC Tilt 8900 Smartphone
I have a problem with my Tilt too.
you might need to replace the SIM card connector. you need to disassembly the unit and replace this connector with its flex cable.
you can find this part on eBay for about $15.
if you need directions for disassembly your device, you can find them here:
HTC TILT/KAISER service Manual
Aug 29, 2009 | HTC Tilt 8900 Smartphone
No SIM card inserted
blow the hole of the slot theres is probably dust and dirt blocking it from going through
Jul 27, 2009 | HTC Tilt 8900 Smartphone
I posted a little too early. There was one other trick I've used and I guess I should have started with that. The problem is indeed related to the SIM not getting enough downward pressure on the contacts to be recognized.
So I took a small strip of paper, about 3/8" by 1 1/4". I folded it three times. When you fold it one end will be closed and the other end will have the two edges of the paper that can open up. Using the open end will make it harder to slide under the bracket. So you will want to take the closed end and gently side it above the SIM card underneath the silver metal bracket that holds the SIM in place.
I used a post-it note as the paper but anything will do. It was working with just a double thickness but I wanted to be sure so I moved up to three layers. Depending on the tolerances of your phone you might be able to only do double layer and still be able to slide it in. Or you might need to go to four layers.
I hope this solves it for you.
/text for Google's indexes so others can find this: HTC Kaiser 8925, Cingular 8925, AT&T Tilt 8925, SIM Card is missing,
Apr 23, 2009 | AT&T 8925 Tilt Smartphone
Sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 16, 2009 | HTC Touch P3450 Smartphone
HTC Tilt When I put my sim card in the phone it tells me "Sim Card Missing" and When I put the sim card in another phone it works fine.
when i put my sim card in a at&t tilt phone it tells me to enter a sim block code. when i enter my puk number it tells me its invalid. what code should i enter
Sep 12, 2008 | Lands Phones
HTC Tilt 8900 Smartphone Logo
1,012 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
