Question about SanDisk Sansa Clip MP3 Player
My sandisk wontturn on off the charger
My SanDisk Sansa clip turns on when its charging but as soon as i take it off the charger
it wont turn on
  • 8,596 Answers
Make sure the hold/lock is not enaged.
If not:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
Doesnt turn on
THis happen to me to then i turned on i deleted all my song then it turn on idk if u want to try this
May 23, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont turn on
Make sure the hold/lock switch is not accidentally engaged
Feb 11, 2009 | SanDisk Sansa Clip MP3 Player
Charging my SanDisk Sansa Clip MP3 Player
You will definitely need to get that USB charger cable.
Dec 09, 2008 | SanDisk Sansa Clip MP3 Player
Wont turn on.
http://www.sandisk.com/sansa/#/support-0/
Aug 10, 2008 | SanDisk Sansa Clip MP3 Player
Wallcharger for Sansa CLIP...
Get a USB wall charger - one end plugs into the wall, and it contains a USB port. Readily available from Walmart, Target, etc. I would recommend the Sansa specific one, available at become.com:
USB Ac Charger Sandisk MP3 The Macally USB AC charger is a USB power adapter you can use to charge your Sansa MP3 Player at home, on the road, or whenever your Sansa is not ... Read More
$18.99 - $19.99 at 3 stores
Jun 18, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa clip
You need the latest firmware update from Sansa' website - may require a restart of computer after performing.
Apr 18, 2008 | SanDisk Sansa Clip MP3 Player
Battery wont charge with an AC adaptor
Dear Verona,
Sandisk is a brand that is best used with its own. There are two degrees of separation here. 1) It is a cell phone charger
2) The charger is not in its family.
With both things working against the machine, it is not a surprise it will not fully charge.
Happy Surfing!
Feb 07, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
83 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
