Question about Garden
Edger blade will not turn
Electric Edger motor runs while squeezing the trigger, but the blade will not turn consistently, or rarely. I see it trying to turn, but it isn't constant. Any ideas? Can it be repaired?
  • gbows Mar 01, 2009
    The shaft turns intermittently, with no consistency. I can hear something inside spinning, it's just not turning the shaft. Assuming Mr. Fixit is right again, where would I find the small drive gear?
  • clyde2j2
    clyde2j2 May 11, 2010
    Can you tell if the shaft that the blade is on is turning.
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
electrodynam
  • 35 Answers
SOURCE: Weed Eater ELECTRIC Lawn Edger sseized up. If I
If it is seizing up it is probably not worth fixing,but there is a chance that you just need to change the brushes.You can usually pull these out pretty easially,and have a look at them.If they are all eaten away try replacing them.Again though if it is actually locking the shaft,and pulling the brushes out does not free it up you may have to just toss it.
Posted on Jun 06, 2009
SOURCE: Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Posted on Jul 25, 2009
  • 21 Answers
SOURCE: Gas Edger Blade
you can try to drive something between the blade and the washer (like screwdriver) to create more friction or try holding the washer with channel locks might have left hand threads and you are actually trying to tighten. if that doesnt work probably need an impact wrench. Go to a auto repair or tire shop with mechanic and give them a few dollars for luch or dinner and let them try with air tools
Posted on Aug 04, 2009
  • 113 Answers
SOURCE: black and decker 1.25 hp edger won't start
If it's electric, you probably cut the wire internally by kinking it or stretching the iwre beyond it'd capability.
Posted on Aug 22, 2009
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
I have a RYOBI pole saw that starts fine, but there is a disconnect between engine and saw blade. The blade will not turn.
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
Aug 26, 2011 | Garden
Problem with my B&D LE500 lawn edger. Will run good then quits. pressing trigger several times edger starts. may keep running or quit. are there points or something electrial that could be problem?
Check the switch, it could burnout. The trigger switch made on this model are very cheap and can not supply current to motor for a long time without burning out. So it could be that switch has melted, and plastic is covering parts of the terminal.
Apr 29, 2010 | Black & Decker Le750 Lawn Edger
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Cant change blade, holding stem is stuck
holding steem, guess you are talking about the shaft that holds blade.
move the shaft down by squeezing the trigger.if shaft doesnt move you have a trigger problem or motor problem.
Oct 03, 2009 | Bosch Saws
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
Black and decker 1.25 hp edger won't start
Aug 21, 2009 | Garden
Jun 13, 2009 | Ryobi Garden
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
