It would be best if you posted up the p codes. Usually the misfires are cause by bad coils. I would start by changing spark plugs. then seeing if that fixes any of the misses. Then I would "borrow" or buy new coils(the things that go over the spark plugs) and see if that solves the problem. If you replace coils and still happening, then look at the wire harness as it gets old and brittle and cracks.
With the car running rough it could cause the harsh shift but if it is staying at 5000 rpms then the ****** is about to go out on you. The rough idle sounds like a vacuum leak. If you can keep the car running at idle listen for a sucking type sound. That would indicate where the vacuum leak is.
Most likely cause is a crack in the distributor cap. This allows moisture to penetrate the cap and causing misfires and stalling. This would be the 1st place to check.
a misfiring engine wont have enough power to sustain a load thats why when you shift it dies.you need to retify the problem first.check for any presence of water in the diesel fuel.Not enough fuel pressure
Here is a list of possible causes. You should not drive the vehicle if the check engine light is flashing all the time, you can cause even more damage. It could pay to have a professional find the real cause.
Spark plugs that are incorrect for the application, cracked, improperly gaped or worn can cause the engine to misfire or run rough at all times. An IC module that failed to correctly control the ignition coil(s) will cause the engine to misfire or run rough at all times. Poor connections, broken wiring or wiring that has shorts to ground can cause the engine to misfire or run rough at all times. NOTE: Check connectors that might be pulled apart as the engine flexes or wires that short to ground as they pass near brackets or shorts to ground on the exhaust manifold. Fuel injector(s) that are shorted, plugged or partially restricted can cause the engine to misfire or run rough at all times. An ignition coil(s) that has low output, corrosion on the coil tower(s), is carbon tracked or arcs to ground will cause the engine to misfire or run rough at all times. A PCM that failed to properly control the injector or ignition timing will cause the engine to misfire or run rough at all times.
