Question about Xerox Office Equipment & Supplies
B&W Xerox copier XC23 has code J7 and will not print
J7 code states it needs a new drum. The drum is fine. The copy count on the machine is 60003. The copy count probably triggered this problem. Is there a way to reset the count? Do I have to get a new connector part for the end of the drum? Could the count also indicate that the copier will also have to have the toner replaced at the same time?
  • 239 Answers
This machine has a battery on the main board. The battery might failed, they will last for about 7 years. When the battery fails then so will the NVM.
Some NVM information can get garbled. This problem may be associated with it.
Some of the values can be checked and changed in diagnostics, most cannot.
If you replace the drum and the machine will not reset, replacing the main board may fix the problem. Make sure the connector on the back of the machine does connect to the copy cartridge.
Sometimes the cartridge you recieve is for a different model. (5322 family)
The socets may not match.
I really do not like to see you spend your money on drums if it does not fix the problem on the machine. Hold on to the drum units until you really find the source of the problem.
Good luck.
Posted on Oct 18, 2009
  • 81 Answers
There is a chip on the back of the drum unit that keeps count. It cannot be reset. You may try to find a replacement chip on the internet. I would recomment the rechargerstore.com They have good products. I do not know how long your drum will last, you may end up having to replace it for copy quality problems at some point.
Posted on Mar 03, 2009
  • Sanjay Puri Dec 26, 2012
    Yes , thanks , I did manage to replace the chip , and the machine works fine ..
XEROX 212 J 7 PROBLEM
J7 means the copy cartridge, ( drum unit) needs to be replaced or rebuilt.
May 19, 2011 | Xerox Office Equipment & Supplies
I want to repair J7 in Xerox 5317
If your ERU (drum unit) has made 40.000 copies you can repair it using the repair kit that includes the fuses.If it has reached 80.000 copies then you need to replace the drum.If you can't find either then take out the drum,locate the small pcb at the rear end (next to the gears) and replace the 2 small fuses.This requires a soldering iron and knowhow
Apr 06, 2010 | Xerox 5305 Copier
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
How do you reset the j8 code
J7 Drum unit due for replacing J8 Wrong drum unit or power was turned on after J7 displayed
U have to insert the new dram unit or change fuze 0.018 A in drum unit
Sep 17, 2009 | Xerox Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Xerox XD100 that is showing a code J2
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Jul 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox Docuprint C1618 Colour Laser
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Mar 24, 2008 | Office Equipment & Supplies
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Jan 05, 2008 | Office Equipment & Supplies
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
325 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
