Question about Pioneer Audio Players & Recorders
I'm trying to use wireless headphones with my Pioneer VSX-810 by connecting the RCA (red+white) into one of the audio outs in the back (ie. CDR, or VCR) but I"m getting no sound. The headphones connect well through the front headphone jack (using RCA-headphone adapter) but I don't want to have to turn the speakers off everytime I use the headphones, I'd rather just be able to mute the receiver and control the volume with the headphones. All my audio into the receiver is digital optical, can't my receiver switch the digital in to analog out?
  • 10 more comments
  • Michael Smukler
    Michael Smukler Feb 28, 2009
    all power works. As I said, the headphones function normally when plugged into the headphone jack but I want to plug them into the RCA out of the receiver.
  • Michael Smukler
  • Michael Smukler
    I'm not sure that's right because both my receiver manual and headphone manual suggest that it should work. Are there any other solutions I could try to plug the headphones intot eh back of the receiver?
  • Michael Smukler
    it still doesn't work, even when volume is up
  • Michael Smukler
    I have done this, but it is ugly plugged into the front of the receiver (where the headphone jack is)
  • Michael Smukler
    the headphone are analog
  • Michael Smukler
    "3.5mm Jack to RCA converter will work in analog as well. You can buy the coverter from the following link:"
    As I said, I've done this. I don't want to plug into the headphone jack in the front, I want to plug it into the RCA output in the back. Is there a configuration that my receiver must be in to do this?
  • Michael Smukler
    is the "line out" different from the audio outs for devices to record through the receiver? Cause that's all I see, and those aren't working
  • Michael Smukler
    "you can get the normal head phones instead of analog head phones and they will support as for what you really wanted.the sound will be clear and sharp in normal head phones.just try that it will work for sure"
    -this doesn't make sense to me. Forget it. I'm already trying to get my money back from FixYa, I'm pretty sure I've soveled the problem myself with no help from "experts". Thanks anyway.
  • Michael Smukler
    problem not solved, but I'm going to ask elsewhere. Not interested in advice like "is the power turned on".
  • Michael Smukler
    I was wrong, i didn't solve the problem. I tried using the preouts set for an extermal amp but they are subject to the turning the speakers on/off as well. So I've deceided to live with it or buy a digital to analog converter (if I can find one under $70).
  • Michael Smukler
    and I paid for a solution which I didn't get.
  • 423 Answers
What you need is a simple A/B switch. Connect it inline from your Surround Output (Right and Left) on the back. Connect your speakers to output A and your headphone cable to output B. Then all you have to do is move the switch to have the sound go to your speakers or to your headphones. The switch can sit behind the unit so it's out of the way. You may have to work on the configuration to suit your needs, but a switch will work for you. Have fun with your headphones.
Rob
Posted on Feb 28, 2009
    Scholar:
  • 85 Answers
Is your problem got solved.
if yes.
thanks for keeping us updated.
for further help keep updated.
    Sergeant:
  • 326 Answers
You can get the normal  head phones instead of analog head phones and they will support as for what you really wanted.the sound will be clear and sharp in normal head phones.just try that it will work for sure.
    Brigadier General:
  • 8,619 Answers
Hi
You can offcourse do that by using a 3.5mm Headphone Jack converter which converts RCA to 3.5mm Stereo Jack.
Please revert for any clarifications.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 28, 2009
    RCA Male to 3.5mm
    3.5mm Mini Male to RCA Female
    Thanks
    Rylee
    var pr_locale = "en_US";
    var pr_page_id = "LT1648";
    var pr_merchant_group_id = 10215;
    var pr_site_id = "2";
    var pr_zip_location = "http://common.csnstores.com/";
    var pr_write_review = "http://www.mountsandmore.com/asp/productReview.asp?PrSKU=LT1648";
    var pr_style_sheet = "http://common.csnstores.com/pwr/includes/css/override_pwr_styles.css";
    var pr_snippet_min_reviews = 1;
    snippet(document);
  • 10,594 Answers
If you MUTE main signal / output, you will not get any sound in wireless headphone.
You should lower volume of receiver only to get sound in headphone instead of putting the receiver on mute.
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Feb 28, 2009
    Regarding digital and analog audio issue, please find Line Out RCA terminals on receiver to hook wireless headphone there.
    As I said before, your Pioneer receiver should have RCA jack at rear called LINE OUT.
    Wireless headphone base unit will be hooked there to get sound and transmit it to headphone.
    May be its written as MONITOR AUDIO OUT, words can be different but basic thing is that jacks have same audio out what you listen in speakers through volume control.
    Would you like to share how did you solved that problem "without" experts advise?
    You got every possible info from experts and now saying you solved it yourself?
    You just said that..
    " I'm pretty sure I've soveled the problem myself with no help from "experts". Thanks anyway."
    Alright, as you wish.
    We all tried to solve this little problem.
    Can you post snap of rear of receiver and wireless headphone base unit connecting side to find out whats happening there.
    Scholar:
  • 165 Answers
Its not possible with your device to turn it to analog out.
    Sniper:
  • 113 Answers
check out the battery in the headphones.
and let us know.
Good Luck!!!
neo
  • nenotech_neo Feb 28, 2009
    If you want to receive digital audio into your wireless headphone, than make sure the wireless devices only support analog audio.
How do I hook up pioneer stereo receiver VSX-D704S to laptop
Use a headphone jack to rca adapter. Plug headphone into laptop headphone jack and connect rca ends to whichever input you want to use on the pioneer.
Oct 08, 2016 | Pioneer Audio Players & Recorders
How do I get the powered subwoofer to work with a pioneer VSX-D510
You plug a subwoofer RCA cable into the Subwoofer Preout from the back of the VSX-D510 and to the input on the back of the subwoofer. If there is a red / white connection don't sweat it, just use the red. Should work fine.
Feb 14, 2016 | Pioneer Audio Players & Recorders
Im having trouble hooking up my equalizer to my Pioneer audio/video multichannel receiver vsx-814
Looking at the back..bottom right corner is CDR/Tape in and out. Connect the in on the eq to the out of CDR/tape, connect the out of the eq to the in of CDR/tape.
You should then be able to use the CDR/tape monitor button to switch the equalizer in and out.
Sep 25, 2014 | Pioneer Audio Players & Recorders
How do i assemble a pinoeer stereo system model VSX-504s and model CLD M403
Use RCA audio cables to connect the CD player to the receiver. The CD player should have two RCA jacks labeled "audio out"; On the top row one jack is red and the other white. On the Pioneer receiver in the back, there's several rows of RCA jacks. On the bottom , just to the right of "tape monitor"it is labeled "CD". Plug the red RCA cable into the red jack on the bottom and the white plug into the white jack on top of the red jack. On the front panel of the pioneer receiver is a small button labeled "CD". Press that button to listen to the CD's.
images?q=tbn:and9gcrfpubn4rfeo_gjllmgnn8g_iqmawgbbh3jscq6cfxrh7y-3f7qegThe red cable is fro the right channel ( right speakers), and the white is for the left.
Jun 06, 2014 | Televison & Video
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
How do i connect a subwoofer to my vsx-9700s
on the back of the pioneer, you have a subwoofer preamp output jack, probably colored black, as opposed to red or white. stretch a rca cord between there and the red and white (or lfe) input of the sub. youll then have to check the amp setup menu and make sure it has the output activated. good luck
Feb 11, 2010 | Audio Players & Recorders
No Sound on TV/SAT setting on Receiver.
Most TV has Audio Out RCA jack at rear and it gives same TV Sound as coming from its speakers.
Hook audio wire red white RCA pins at TV Out and plug these pins to TV/SAT input of receiver. Select TV/SAT input in receiver to get TV program sound coming out from TV.
Hope that info will help you.
Sep 15, 2009 | Pioneer VSX-D509S Receiver
I have a audio/video multi-channel receiver VSX-D810S digital processor, probably about 7 years old. How do I hook up my ipod to play music out speakers in my home, same as cd's?
Check Radio Shack, thay make an adaptor with a white and red audio plug that can connect to an input on the receiver (AUX) the other end goes into the headphone jack on the iPOD.
Aug 17, 2009 | Pioneer Audio Players & Recorders
Listen to TV through my vsx-454
  1. Go To RADIOSHACK
  2. GO buy RCA Cables(red,white,yellow)
  3. If your Tv Has An RCA Output Connect the RCA Cables @ one End of the TV.
  4. Connect the Other End to THE VCR2 Input.
  5. SWITCH THE INPUT TO VCR2
Jan 16, 2009 | Pioneer VSX-454 Receiver
Logitec Wireless Headphone
If there is an RCA output (red & white), you can get an RCA to 3.5mm mini jack adapter at a store like Radio-Shack in the US or the Source in Canada.
Nov 13, 2007 | Logitech Bluetooth Wireless Headphones
88 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
