Question about Heritage Dryers
I have a Heritage Ceiling Fan model M42UL. The 3
I have a Heritage Ceiling Fan model M42UL. The 3 speed switch is broken. looking for a wiring diagram for the switch to fix the fan, the light switch works.
SOURCE: Heritage Ceiling Fan
the fan works on the remote but not the light unless u push it a million times just right
Posted on Oct 04, 2009
  • 202 Answers
SOURCE: need wiring diagram for a heritage 5law52ab
blue wire is for the fan, black wire is for light and white wire is neutral. Blue and black are hot(live)
Posted on Apr 01, 2010
SOURCE: Ceiling fan capacitor hook up problem. I have a 3
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
Posted on Jun 11, 2010
ftw1952
  • 10319 Answers
SOURCE: I am looking for a
Look at this website for helpful hints for a switch replacement. Many hardware stores stock switched for ceiling fans. 99 percent have three speeds too
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
Posted on Jan 29, 2011
  • 47683 Answers
SOURCE: I have a Heritage Fan, model FN42UL. I need to get a replacement for the part shown in the picture. I can't find the part # anywhere. Where can I find this part. directly attaches to the fan chain
most any store that sells fans will have that part .hope you payed attention to which wire when where tho
Posted on Jan 01, 2017
Broken 3-speed ceiling fan switch
Observe and read manual carefully
Jul 23, 2016 | Dryers
I have a Heritage Celing fan model M42UL. I connected it to work with the remote control. It does not work with the remote anymore. How can I reconnect it to work without the remote?
Make sure your dip switches match in the receiver & transmitter. If you have a wall switch, make sure it's ON. If there are pull chains on the fan, press the high on remote then pull chain until it's on high speed.
Aug 29, 2015 | Heritage Dryers
Wiring diagram 3 speed ceiling fan
Call 1-888-227-2178 with model & serial numbers of fan. Should be on top of motor housing.
Jun 11, 2013 | Dryers
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
77020 fan switch dont turn off. i need a diagram please...
Copy following link for wiring 3-speed fan switches
May 25, 2011 | Speed Ceiling Fan 3-speed Switch By...
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
Dryers Logo
681 people viewed this question
Top Heritage Dryers Experts
roeb
Michael Galve
Michael Galve
Ottoniel
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
