Question about Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
Running xp on dell inspiron 5150 laptop, using scsi to usb converter (software installed), nikon software is also installed (ver3.1.2),
when I open nikon software, it says "nikon scan was unable to find any active devices".
Unit is turned on. and shows in device manager.
Is the unit incompatable w/ the scsi to usb converter? Or am I doing something wrong?
I have tried booting computer first, then turning on scanner. and the other way around.
Help?
  • Anonymous Mar 22, 2009
    Thanks for the answer, I was worried about that, so I took scanner to different xp machine, installed the card, booted everything, xp found everything fine, Installed the software from nikon. 3.1.2
    Rebooted, pc found card and scanner, Ran software and nikon software says... no scanner found. Read something about needing to update flash bios on a web site. Could that be it? wondering if i need to find an orginal version of the software instead of the new version?
    help?
    Scholar:
  • 48 Answers
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Posted on Mar 21, 2009
SCSI to USB conversion for Film Scanner
SCSI to USB converters are available, but I doubt they will be of much help for you, you'd still need a special driver for your scanner.
Windows 7 Professional, Enterprise, and Ultimate support "XP Mode", essentially a Windows XP environment running in a virtual machine. I'd try to get the SCSI interface card and scanner to run inside the VM as a workaround.
Feb 07, 2010 | Acer ScanWit 2720S Film Scanner
Nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on adaptec.com site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Mar 22, 2009 | Nikon LS 2000 Film Scanner
Problem installing external hard drive
Run device manager and keep it running during the installation of drivers. It will take a bunch of drivers, but it will work and it will stop once it has all the drivers installed.
Dec 28, 2008 | Dell (073VDD) SCSI Controller
I need to connect a Nikon LS2000 Slide Scanner to a Power Mac G4
I originally had the same problem but with a G5. Since Nikon never updated the software for the LS2000 to work with Apple I ended up buying a FR1SX adapter from RATOC Systems: http://www.ratocsystems.com/english/products/FR1SX.htmlwhich connects the SCSI pins to a Firewire cable. Then I purchased the VueScan software from http://www.hamrick.com/vsm.html. The scanner worked for several years with this combination.
Dec 17, 2008 | Nikon LS 2000 Film Scanner
PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
Nov 18, 2008 | Nikon CoolScan V ED Film Scanner
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software (www.hamrick.com). This works perfectly on LS2000 - Macbook Pro combo.
Jun 02, 2008 | Nikon LS 2000 Film Scanner
Nikon Scan doesn't recognize scanner
I have the same problem (on XP, Nikon Scan 3.1.2) ... IF I turn the scanner on before the computer (or turn the scanner on and then reboot) then Nikon Scan recognizes it. Can't say I'm happy with the solution, but it works consistently for me.
Apr 18, 2008 | Nikon LS 2000 Film Scanner
Drivers for Nikon LS 1000
I believe that's a SCSI-interface scanner, making its setup more complicated than there's room for here. Here's what Nikon says about SCSI setups: <http://tinyurl.com/2wxp7p> and the Nikon software for the LS2000 and LS3000 (but maybe it'll work for the LS1000 too) is at <http://tinyurl.com/2qko5e>. There's a good set of detailed installation instructions under cineman's entry at <http://hardware.mcse.ms/archive47-2005-6-203500.html>. Good luck!
Lenny
Feb 11, 2008 | Photography
NIKON LS2000 SCANNER
this scan works with SCSI interface not provided by default in PC. So scan uses to come with SCSI board .. you need to install it into your PC .. yes
Nov 19, 2007 | Nikon LS 2000 Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Nikon LS 2000 Film Scanner Logo
327 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
