Question about Frigidaire FRT18S6AW Top Freezer Refrigerator
I have a frigidare fridge model frt18b4aw4 out in my unheated garage that the fridge is keeping cold but the freezer is not freezing the items in there.
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
murdozzz2
  • 75 Answers
SOURCE: Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Posted on Dec 11, 2007
  • 142 Answers
SOURCE: FREEZER IS COLD BUT NOT FREEZING WELL,FRIDGE IS NOT AS COLD AS IT SHOULD BE
Your freezer fan has stopped working or jammed. It's also possible that your defrost timer has stopped working and that the airways in the freezer are clogged with ice and the air can't circulate to the fridge. One of the two. Good Luck!!
barneyluc
Posted on Oct 03, 2008
  • 401 Answers
SOURCE: Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Posted on Jan 05, 2010
SOURCE: Freezer won't work in garage in cold weather
Maybe read these threads...
http://www.whitegoodshelp.co.uk/wordpress/freezer-defrosted-can-you-put-a-fridge-feezer-in-a-garage/comment-page-2/#comment-9162
Steve Arnell
Posted on Dec 21, 2010
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
HAVE A GE PROFILE SIDE-BY-SIDE REFRIGERATOR ABOUT 10 YEARS OLD THAT NEEDS A GARAGE REFRIGERATOR KIT INSTALLED. IN MY UNHEATED GARAGE AND NOT WORKING IN FREEZING TEMPERATURES. TRIED A 100w LIGHTBULB...
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Dec 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Self defrosting fridge/freezer
Good day,
That is normal if the room or area is too cold. If the room temperature drops below 55 degrees Fahrenheit then that problem will start to show up.
All manufacturers state the machine will start to unbalance below that temperature.
Mar 13, 2010 | Bosch Refrigerators
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
New Fridge/Freezer placed in Garage,when ambient temp falls freezer stops working
You do not say what type of Fridge/Freezer it is. Some types will not work in cold ambient temperatures, ie unheated garages.
Check the user instructions, if it does not say anything about this, get onto the service department for advice.
Dec 08, 2008 | Refrigerators
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Dec 11, 2007 | Refrigerators
Frigidaire FRT18S6AW Top Freezer Refrigerator Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
