Question about Dryers
START AND RUN PROBLEM
PUSH START BUTTON ON DRYER IT STARTS, RELEASE BUTTON, IT STOPS. REPLACED START SWITCH, SAME THING, REPLACED CONTROL BOARD, SAME THING WHIRLPOOL GAS DRYER MGRH865QDS
  • 2 more comments
  • funjager Mar 01, 2009
    MY MISTAKE DRYER IS WGD5900SWO HAVE REPLACED CONTROL BOARD, NO DIFFERENCE, NOW LOOKING AT THERMISTOR, THERMAL FUSE, AND MOTOR RELAY THANK YOU FOR RESPONSE THE STOVE WENT OUT AT THE SAME TIME, GOT MODEL NUMBERS CROSSED
    OK I JUMPED THE TWO BLUE WIRES TURNED THE CONTROL DIAL DRYER RUNS, DOES THAT MEAN THE RELAY IS SHOT.
    THANKS FOR WALKING ME THRU THIS
  • WRMtech
    WRMtech May 11, 2010
    Can you verify model number, this model comes back as a Maytag free standing range
  • 70 Answers
Check the motor relay. there are 4 wires( 2 are pink and black) this goes to the coil of the relay and must show resistance(closed) you can also jump out the 2 blue wires and see it the unit keeps running. The part number for the relay is: FSP3405281 approx 40.00US
Posted on Mar 01, 2009
  • WRMtech
    WRMtech Mar 01, 2009
    yes, the relay is bad. I have supplied the part number for you
  • WRMtech
    You are very welcome
The start switch start the dryer but shuts itself when we release the button
Several different components could be preventing your dryer from continuing to run when the start button is released. The wiring diagram and other technical information for your dryer are shown in the image below. When the start (PTS or Push To Start) button is pushed, the PTS contact is closed and voltage is supplied to the drive motor. Start voltage is also sensed through the blue/black wire that is connected to the P1-5 Start Sense pin on the control board. When the control board senses the start voltage, it normally applies 48 volts DC voltage through the Pink/Black wire to the motor relay to hold the contact closed between the two blue wires attached to the motor relay that supplies normal run voltage to the drive motor. With the start button taped down, the motor continues to run since it gets voltage through the closed start button. Since the motor stops running when the start button is released, it indicates that you have one of these 3 failures:
Broken or disconnected Start Sense wire.
Failed electronic control board that is not sending the 48 volts DC voltage through the motor relay Failed motor relay. Wiring failure between the components.
Since the motor relay and the heater relay are both exactly the same part, you could unplug the dryer and switch the motor and heater relay to see if the dryer will stay running. If it does, then you just need to order and replace the bad relay.
Jan 05, 2017 | Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
When the push start button is pushed in the dryer starts and every thing is ok until you release the button then all stops. I have replaced the bank of push button and just relaced the timer controls.
Good day,
Seems you've covered the timer and push to start switch.
If so then....
The principle the system runs on is, if the timer is turned on, 2 wires come out of it to run the the motor.
The first goes to the push to start switch and when pressed it sends power directly to the motor.
The second wire goes to the motor, but thru a centrifugal switch that must be up to speed before it sends power to the motor.
That is why it continues to run even when you release the start button.
The centrifugal switch is a part of the motor.
Either the centrifugal switch failed, or the power wire to it is disconnected or broken.
Feb 11, 2010 | Washing Machines
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer
check also,
  • the other ends of all cables connected to the relay,
    if the other end of any part of the latching circuit has loosened, the relay will not latch closed when the start button is pressed.
  • Door Switch, it is part of the latching circuit
Sep 21, 2008 | Kenmore 62872 Electric Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
Dryers Logo
189 people viewed this question
Top Dryers Experts
