Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
My dyson roller stopped spinning - Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
  • Anonymous Apr 11, 2009
    My Dyson 17 animal vacuum sucked up a canvas handle. I pulled it out. The roller stopped rolling. Help.
    New Friend:
I had the same problem hit the reset button never heard a click but it started spinning again!
Posted on Jun 30, 2013
Hairs stuck in the ends of the roller
Posted on Feb 28, 2009
2 Suggested Answers
  • 143 Answers
SOURCE: my dyson animal 14 roller stopped spinning!!! help!
remove base cover on foot and check for hair buildup. remove, re-assemble and test. of not it is probably either broken belt /drive vane and will require shop service
Posted on Sep 14, 2009
Testimonial: "thank you "
Have a dyson dc41 brush head wont spin so tried another which i bought this wont spin either the hoover picks up well with the hose what could be the problem be please
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 30, 2017 | Dyson Vacuums
Dyson dc 50 issues
Have you tried replacing the rubber drive belt for the roller?
Jun 07, 2016 | Dyson Dc50 Animal Bagless Upright Vacuum -...
Dyson brush roller spins intermittently. it starts out good but then stops
Do you have a burning rubber smell at the same time? Turn the machine over and remove the bottom cover. Hook a loop of cord under the belt, pull it up wards and pull the brush out. Remove one end cap and pull the spindle out from the other end. Remove the fluff and hair that is tied around each end.
This shows quite well.
https://www.youtube.com/watch?feature=player_embedded&v=cYqOEpZgocg
Put the brush back and see if that fixes it. If not, then you need to change the two belts, and possibly the clutch. The same guy at Vacuum spot shows clutch servicing, but you may wish to get a professional to do it. How to check the Dyson DC04 Roller Brush Bearings
Mar 21, 2016 | Dyson Vacuums
Dyson dc24 roller brush stopped spinning
There are two switches to check. The push button switch on the handle and the other one that turns brush roll on when you recline the handle back.
Feb 02, 2018 | Dyson Ball DC24 Bagless Upright Vacuum
The roller wont spin when I lower the handle
Hi its Darran at Dyson.
It is possible that the item has caused some damage to the clutch. We would advise following the onilne checks at www.dyson.com and clikcing on the support section.
If this doesnt resolve the issue, please call our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The roller that spins with little brushes stopped suddenly and no longer spins. I pressed the red little knob at the end of the roller but it doesn't fix the problem.
open up the roller area check to see if somthing got picked up and jammed into the rollers so that it can't work, a rock or a screw or you might even have a large amount of string or fibers wrapped around the shaft or brush keeping it from rolling
Feb 19, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Ran over a cord. Wrapped around the roller brush.
it was the belt should cost a few dollars at bimart or like ace you can do this by taking rollers out from bottom of vac. u can use a butterknife to unscrew it ull see the belt.
Feb 08, 2010 | Vacuums
Roller wont spin
is there hair, strings, twine wrapped around the roller? perhaps this is the issue, is there still suction by the rollers or has this stopped as well?
Jun 12, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
451 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
