Kenmore washmachine will not fill with water
I replaaced the water valve on my kenmore wash machine and it worked fine for three loads and now it wont fill but when you turn the dial it starts to agitate could this be a bad dial or broken wire and how do I go about finding out which it could be
  • 70 Answers
If the unit is agitating with no water in it, you will need to replace the pressure switch( aka Water level switch) it is located up inside the control panel and has 3 wires and a hose on it.
Good Luck!
Posted on Mar 01, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Water problem
Apr 01, 2009 | Washing Machines
My washing machine wont stop filling with water
sounds like the hot cold water valve is bad,you also have the water level switch,the switch has a water level hose on it,some times the hose comes loose,chech y=that also,let me know what you find-mike
Mar 17, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Wont fill with hot water
3 things to check.. Make sure that you are getting hot water upply. Check your water inlet valve. IF both are ok then check the switch to make sure that it is sending power to the water inlet valve to let it open. These parts can be found behind the knobs after you remove the cover
Feb 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series will not load hot water
It sounds like need to make some voltage checks on this job. When you set the fill cycle to hot & start the machine do you hear the valve buzz? If you do then the valve is causing the problem.
Feb 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 model 110.20912991 wont stop filling with water
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Jan 27, 2009 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
