Question about Apple iPhone Smartphone
IPhone won't do anything!
When I turn on the iPod, it tells me to connect it to iTunes, the thing is that it is connected to a USB. Then at the bottom it says "Slide to Unlock" but when I try, it doesn't slide. It then just shuts off a second later with the loading circle, and does that everytime I turn it on. It doesn't connect to iTunes for me to use the ZiPhone firmware either. What do I do?!
  • 1 more comment
  • sandy_n2 Feb 28, 2009
    i restored the iphone but the same problem keeps occuring, it won't stay on for more than 5 seconds without turning itself off. and it's plugged in with the wire and being charged, so I don't get why it still happens
  • ruthangie1 Mar 01, 2009
    help pls tried everything nothing is working
  • Anonymous Apr 17, 2009
    i put my i phone on the charger and the the thing that tells me its charging comes up and then the apple comes on then the usb cord and a arrow pointing to itunes come on.
    President:
  • Apple Master
  • 688 Answers
Before you connect your iPhone or iTouch to iTunes.
Try and put the device into DFU Mode.
Plug your USB cord into your Device and Not into your computer.
Turn the Phone all the way off by holding the power button until the Red Bar appears and Slide it off..
Hold the "Home" Button Down for 5 seconds.
Then Push and Hold the "Power" Button while still holding the "Home" button and count to 7
Let go of the "Power" button while still holding the "Home" Button and Hold the Home button for approx 26 seconds.
The screen may or may not go blank with lines. No Worries!! now plug the USB into the computer with iTunes open. If the iphone is in DFU mode, iTunes will come up with a popup that says, "Itunes has detected an iPhone that is in recovery mode. Your must restore it"
Once this occurs, you can restore your device with any firmware by pressing "SHIFT" on your keyboard and "Clicking" Restore with your Mouse. Restore your device and let it mount to itunes.
If you are unlocking the device, I would suggest using "QuickPwn" you can get it HERE
You can download Apple iPhone Firmware HERE, when using quickpwn you will need to upgrade your firmware to 1,2_ 2.2_5G77...NOT 2.2.1
(TIP: Don't restore your iphone with custom firmware in iTunes. Restore with the original Firmware and Unlock or Jailbreak letting Quickpwn make the custom firmware....Also if you have a 3G do not ungrade in itunes to the 2.2.1 firmware, it changes the phone modem baseband and renders it "NOT" unlockable)
Posted on Feb 28, 2009
Getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
Feb 26, 2011 | Apple iPod touch Second Gen (8 GB,...
When i switch on my ipod touch, it's telling me to connect to my computer and when I do connect, it's still the same thing
you may have to restore it....but you'll lose all your data here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
Sep 06, 2009 | Apple iPod touch
When i plug my ipod touch into the computer this comes up..HELPP
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
My ipod is so screwed up PLEASE HELP
you can reset its password....but you'll lose all your data. Here's how...
Sep 03, 2009 | Apple iPod touch
Ipod disabled connect to itunes
you can reset its password....but you'll lose all your data here's how...
How do I reset my itouch to a new 4 digit code? I can't remember what code it was set for. After trying a few times it stopped allowing me any more attempts. Now the screen reads ''iPod is disabled connect...
The ipod is writtig 'ipod disabled connect to itunes'
You'll hv to restore the ipod..here's how...
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 27, 2009 | Apple iPod touch
How can i fix and ipod touch that says ipod is
Aug 26, 2009 | Apple iPod touch
My IPOD touch is locked and my daughter forgot the passcode. We don't have access to the computer with the original itunes. The IPOD says to connect to itunes. itunes says it cant connect because there...
all you hv to do is go thru the earlier posts with the same problem....anyways here's the solution again...
Aug 15, 2009 | Audio Players & Recorders
Passcode do not come on it says connect to itunes but i cant because i have a code on my ipod
If its not an ipod touch,connect it to system and when it gets detected as a removable disk,goto ipod_control>device filder and rename to _locked to _unlocked.. If its an ipod touch Force it into recovery mode...here's how
Aug 10, 2009 | Apple iPod touch Second Gen (8 GB,...
Apple iPhone Smartphone Logo
392 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
