Question about HP PSC 1315 All-In-One InkJet Printer
The rollers do not "grab" the paper.
I cannot use more than one sheet in the paper tray because sometimes the printer "grabs" the entire stack of paper or does not take any paper. I have to "feed" the paper one sheet at a time because the rollers do not find the paper.The error light comes on a blinks when this happens and I have to remove the paper and again feed it one sheet at a time.
  • Anonymous Mar 01, 2009
    I have the same problem - multiple sheets of paper go through at once. I have to feed one sheet at a time.
  • 25 Answers
I would try a different kind of paper..
Posted on Mar 01, 2009
I have a Dell AIO 926 printer. I loaded paper into the feeder and it grabbed the entire stack and sucked it into the printer. Now it is stuck and I cannot get the paper to budge to pull it back out. ...
in the back side of the printer you will find a removable shaft.. remove that and then try pulling the paper from both the feeding area and the rear side. but remember to remove the cartridges before you do so or you may damage tehm
Mar 12, 2011 | Dell 926 All-In-One InkJet Printer
Printer screen says NO PAPER FEED...when there is paper in the tray.
'No paper feed' is different from 'No Paper' : it basically means that the printer cannot 'grab' a sheet of paper to feed it!
Just remove and loosen the stack of paper from the tray and reinsert the stack making sure that the sides are not jammed hard against the guides.
ps. For good measure, also check for any remains of previously jammed/torned print outs.
Hope it helps!
Jan 07, 2011 | Brother MFC255CW All-in-One InkJet Printer
Paper won't load straight
you will need tools, remove back cover and clean rollers and maunually rotate. hope that helps
Oct 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
My L7580 grabs too many pieces of paper. Instead of one sheet it grabs 4
Time to replace the paper pick rollers located in/near the tray and above on the pick-arm or paper path
May 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Not grabbing paper
Try cleaning the rollers again and fan the paper. When you clean the rollers, use alcohol and a lint free cloth. Don't put too many sheets in the feed tray.
Feb 04, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Hp photosmart pro B9180 does not sense paper
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
Pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Nov 14, 2008 | Konica Minolta PagePro 1350W Laser Printer
Lexmark 5250 printer
Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
111 people viewed this question
Ben Johnson
