Question about Whirlpool Washing Machines
Model lsr6332kq1 washing machine, low water pressure,is there a filter?
  • 130 Answers
Try taking off the hoses and clean the hose filters. if that doesnt help you may need to change the watr inlet valve. Check both ends of the hoses, some have filters at both ends.
Posted on Feb 28, 2009
Hi. I’ve got a HAAS deluxe HWA140SNN too loader washing machine. It’s coming up with a E1 code after about 3 mins during the water filling. What is that ? How can I fix it ?
This is a 'fill error timeout'. Can be caused by low water pressure from blocked filter cups, low mains pressure, faulty isolation valve, or blocked hoses. Can also be a faulty water inlet solenoid which is not opening far enough for a good flow of water. In normal circumstances you hear it RUSHING into the machine rather than TRICKLING.
Haas washing machine E1 code Google Search
Nov 18, 2017 | Washing Machines
Lg washing machine ie fault
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters
Dec 03, 2016 | LG Washing Machines
Bosch WAY32540AU showing LOW WATER PRESSURE but pressure and taps are fine. All filters are clean.
Not sure how you can measure the pressure in the machine, but I think you did. When you did and the pressure in the machine is good, the sensor must be defect. BUT. if you did not measure the pressure in the machine, you should check if nothing is wrong with the water filter on the beginning of the water hose (closest to the tap) and you should check the hose is not bent and nothing is on it, throttling the free water flow.
Feb 24, 2015 | Bosch Washing Machines
Does the Whirlpool, top loading lsr6332kq1 have a lint filter?
I will suggest you steps to check whether your washing machine has a lint filter. Follow the instructions below.
1)Turn off the washing machine and open the lid or door if you have a front-loading appliance.
2)Place your hand on the upper lip of a front-loading or top-loading washer tub and feel around the circumference for a flat tab. Pull out this tab, which is the handle for the lint filter. If you cannot find a tab on a top-loading washer, continue troubleshooting.
3)Unscrew the cap on the top of the agitator in a top-loading washer. The agitator is the center cone inside the appliance.
4)Pull the lint filter out of the agitator and rinse under cold, running water to clean.
5)Slide the filter into position as far as it will go. Replace the agitator cap if your appliance uses a lint filter in the agitator.
Mar 28, 2013 | Washing Machines
How to replace the timer for Whirpool Model lsr6332kq1 washing machine, low water
watch the FIRST 1 MINUTE 10 SECONDS of this video if will show you how to disassamble the control panel,the rest of the video wont be revelant to replacing the timer but it will help to get into the control panel
First step before opening the control panel is to push in the timer knob and unscrew the knob in a counterclock wise direction and then pull the dial off, a screwdriver can be placed behind the dial to assist in removing it. Under the dial are the screws that hold the timer to control panel
here is that video http://youtu.be/9K1KHEogf3c
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Whirlpool Washing Machines
On brand new machine the water pressure is ok (not great as we on low pressure) to back of machine but just dribbling out into tub... Model F&P MW612WH 6.5kg
hi - these machines wioll require sufficient pressure to operate - but low pressure to a certain degree should be fine - takes longer to fill..
Suggest you double check the hoses to the right valve hot/cold etc - usually there is a filter on the hose and one on the inlet valve, hopefully its not blocked.
I cannot see any other component that would be faulty - as you say its brand new...
Jun 24, 2011 | Fisher Paykel EcoSmart GWL15
F17 comes up on my washing machine half way through and the machine stops.
F17 indicates that water is not getting to the machine. Ensure:
The supply line is not kinked/jammed
Water valve is not shut off
Pipes are not frozen
If you have a basin sink adjacent to the washer you can also use that to test that the water pressure isn't too low.
You can also clean the water filter in the machine (Refer to your specific model's manual for instructions)
Zach
Feb 28, 2011 | Bosch Washing Machines
Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Dec 29, 2009 | Samsung WF448AAP Front Load Washer
Water barely trickels in
Could be low water pressure, test by opening the cold tap/faucet on the nearest sink.
Hoses could be kinked, or taps not open or clogged with grime, also there may be filters washers fitted to the hoses, on either end.
Or the valves in the machine could be faulty.
Jul 04, 2009 | Washing Machines
Washing Machines Logo
151 people viewed this question
Dan Webster
Dan Webster
Sal De
